Ok, I've got my own project going on but my parents are redoing their tub surround at their house, and have a nice big window that they figured that they had to tile over it...I've attached some pics...it would really be a shame to cover that up IMO.
This is what I figure would be sufficient protection. (questions in
red)
- Tub surround in 1/2" Hardi; seams and corners taped with Kerdi band
- Kerdi wrapped from 1/2" backer over top of vinyl window surround. Will thinset/kerdi stick to vinyl? If not that leads into the next point.
- 1/4" hardi sloped on bottom plane of window to aid in draining. Can the 1/4" hardi be attached to the window sill with just silicone or thinset? Can the use of screws be avoided?
- Corner where tile meets vertical plane of window to be sealed with silicone.
My reasoning for this method:
The tile/silicone is the most vulnerable to leaks. If there is a leak through the silicone, it would reach the vinyl casing of the window (which I'm assuming is weatherproof from the inside as well), and meet the kerdi where any water will be kept from the backerboard. If I went hardi then kerdi over the hardi, the water could migrate between the hardi and vinyl casing and essentially be "under" the kerdi membrane.
My concerns
- The window should be weather (ie water) proof from the inside, like it is from the outside?
- Freezing - if moisture gets in behind the silicone close to the window pane, could cause some damage if it freezes. Not sure if it's cold enough though.
