Merv,
The preslope just has to lay there, so nothing to worry about. Just view it as a practice run for your mud on top of the liner.
Just make sure your mix is damp enough. You don't want it too damp but if you are going a little slow a little extra moisture is good.
I say mix it like damp sand on the beach. Ball it up in your hand, it should hold the shape but not too much should stick to your hand.
Also the spray bottle idea is good. When I am putting a finish on it I might spray a little moisture on the surface.
But remember the mortar bed doesn't require a slick finish like you might see on a concrete floor. A little rough is good, the thinset sticks better to texture.
But if I float a floor and it comes out a little too rough and I'm not going to tile right away I sometimes skim coat it with some thinset just to keep the surface from wearing off from foot traffic.
