Unread 11-01-2009, 01:15 PM   #1
jb6884
Brian in Ballwin Bath Remodel
Hello everyone..
I'm doing a new shower in the master bath. Onyx shower base, and tiled walls with Kerdi membrane. I ended up special ordering the unmodified thinset per Kerdi instructions and had planned on using this both to stick the Kerdi up and to stick the tiles on the Kerdi. My dilemma is that on the bag of unmodified thinset it says for wall tiles up 4.25". I was planning on doing 12" tiles on the walls. The tiles are porcelain so I'm concerned about using anything but unmodified due to the extra cure time porcelain against Kerdi would require (since both surfaces are impervious to moisture). Does anyone have any recommendation? Will the unmodified that is rated only up to 4.25" tiles work?
_________________________
Ballwin, MO
jb6884 is offline   Reply With Quote
Unread 11-01-2009, 01:22 PM   #2
Deckert
Which thinset exactly did you order?
Brannigan
HeenanGC.com
Unread 11-01-2009, 05:49 PM   #3
jb6884
TEC Sturdi Set 335
Ballwin, MO
Unread 11-03-2009, 10:16 PM   #4
Deckert
Hi Brian,
I've never used Tec Sturdi Set, so I can't help you with the particulars of that thinset. I think thats Tec's 'economy' unmodified thinset. Schluter wants you to use a 'premium' unmodified for Kerdi.
Maybe someone else will chime in that has used Sturdi Set, but I think you might want to upgrade to a higher grade of thinset.
Brannigan
HeenanGC.com
Unread 11-03-2009, 11:06 PM   #5
muskymike
muskymike's Avatar
Hi Brian, welcome! You want to use TEC Full Set Plus or git your hands on some Ditra Set.
Musky Mike
Corrado Custom Tile
Kerdi Shower Specialist
New here? Check this out.
Unread 11-04-2009, 07:58 PM   #6
jb6884
Darnit.. this is what the guy recommended for Kerdi at Tile Source.
Is this sturdi-set stuff ok for the membrane? Also If I'm able to get a more premium thinset as you recommend will I have any issues with the 12" tile on the walls?
Thanks for the advice
Ballwin, MO
Unread 11-04-2009, 08:50 PM   #7
Jory Geigle
Jory Geigle's Avatar
Send a message via MSN to Jory Geigle
ditra set is deffinatly the way to go, like mike said. hydroment makes the ditraset and costs about 12 dollars per bag, thats all we use for kerdi and ditra, cure time is 12 hours at 76 degrees.
J.W.Tile
www.tile-assn.com
Jory Geigle is offline   Reply With Quote
Unread 11-05-2009, 02:37 PM   #8
jb6884
Anyone know where to get Ditra in or around St. Louis? I confirmed my tile source store can get the TEC Full set Plus, but if I can get Ditra I will.
Ballwin, MO
Unread 11-06-2009, 05:26 AM   #9
If you can't get Ditra at HD, order it from www.tile-experts.com.
Unread 11-06-2009, 07:24 AM   #10
Steve C
Steve C's Avatar
Hi, Brian. I'm on the other side of the river from you, and I'm interested in getting some of the Ditraset too. I know the HD's around here usually stock Ditra and some Rondec, but I don't know yet about Ditraset. If I find any I'll let it be known.
Steve C is offline   Reply With Quote
NH bath remodel designs Tile Forum/Advice Board 6 04-06-2009 04:01 PM
Brian & Jean’s Kitchen, ½ bath, and laundry Project bjseibel Tile Forum/Advice Board 8 12-29-2008 05:11 PM
My last bath remodel....for now at least ilverme The Mud Box 11 01-10-2006 10:41 PM
Bath Remodel bd323 Tile Forum/Advice Board 9 01-08-2005 09:30 PM
Bath remodel grisby Tile Forum/Advice Board 4 12-30-2003 12:56 PM
