Using a noble bench is surely a good idea, less prone to failure. That said, it isn't impossible for a corner frame bench to work, from the master himself:
A frame bench will work fine as long as it's strong and strongly attached to the walls.
I would RedGard the whole bench including the surrounding wall areas up to about a foot away. Fix it so no water ever gets in, and you won't have to worry about water getting out.
Things to keep in mind:
all weather wood (what you have) is sometimes wet, and takes a long time to dry out (very problematic to seal)
I would think that using kiln dried framing and sealing with membrane will work though.
Trevor
"The dude abides"
