Unread 01-30-2008, 11:41 AM   #1
brendatim
brendatim's Avatar
kerdi shower along a sloped wall
I want to install a 32x60" kerdi shower system along this wall. As you can see, a lot of the area is sloped. What kind of problems can I expext besides the joist that's in the way where the drain needs to go. I only have two possible places to put this shower and this seems like the best place. http://babysbathroom.blogspot.com/
brendatim is offline   Reply With Quote
Unread 01-30-2008, 01:44 PM   #2
flatfloor
"da Leveler"
flatfloor's Avatar
Hi there
I'm going to move you to the Advice forum where you'll get more attention.
Jim Buckley
Tile Calculator
New Here? Read this!
Unread 01-31-2008, 10:05 AM   #3
brendatim
brendatim's Avatar
I posted in the wrong area and now this post is buried. Anyway, I have a picture of a sloped wall. I was looking for advice for the best shower configuration for this wall. At first I had my sights set pretty low on a 32'x32' shower along a short piece of wall. I think this wall will allow me a bigger shower. It would be nice to have room for a tiled in bench to sit on. I know this wall is funny but it's about all I got to work with because of the window, closet and entry opening.
Unread 01-31-2008, 11:17 AM   #4
xxPaulCPxx
Fit to be tiled
xxPaulCPxx's Avatar
As to cutting that top plate at the bend:
It is fine to cut it as long as you reinforce the connection with a steel nailing plate across the cutout section. A 3" x 18" nailing plate, or something similar, can be found in the metal connectors section of your local Big Box. All you are looking to do is keep each side bound to the other for side to side forces.
Pre- drill the holes so you don't split that old wood. Old wood is strong, but brittle to new nailing.
xxPaulCPxx is offline   Reply With Quote
