Bathroom refresh help: chipped tile, grout fill, caulk help
I have a jacuzzi tub on raised deck with porcelain tile, 20+ years old. I plan to sell the house and need to refresh the look. No replacement tile available. I plan to paint the tile on the deck with Rustoleum Tub and Tile paint ( to cover the pink tiles on the deck face). In prepping for this, I've uncovered issues that need to be fixed first. The Rustoleum paint is a 2 part epoxy if that matters.
1. Rustoleum instructions say to remove caulk. I have done this and found grout and caulk at the junction of the wall to tub deck, and where the tub deck meets the tile floor of the rest of the bath. I got all the caulk out but some grout remains. I cannot scrape it off the tile surface. Do I need to remove all grout in order to replace the caulk after painting or will the caulk adhere over grout?
2. There is grout missing on the corner joint where tiles abutt each other. Should I regrout this area? or take the grout out, paint, then fill corner with caulk?
3. Step area at front of tub: grout missing in chunks on flat part and at edge of one tile. Regrout?
also, several chipped tiles in this area. Should I try a porcelain touch up paint first, before the Rustoleum product, or apply the Rustoleum then fill in the chip area with touch up paint? There is a thickness issue that needs to be filled and the terracotta (?) substrate is visible under the chip.
4. Large gap between floor tile and the vertical wall of the tub deck. I assume this needs to be caulked, but the gap is pretty large. Stuff backer rod in first? I think the caulk needs something to stick to. I am afraid the backer rod might fall out into the space below the tub deck. Please advise on a specific caulk to use for the large void. Needs to be flexible I think.
Jan
