Unread 11-13-2015, 12:07 PM   #1
CountryBumkin
CountryBumkin's Avatar
Send a message via ICQ to CountryBumkin
Thin set or mastic for porcelain "bullnose" to drywall?
I'm tiling a small bathroom floor with 18x18 porcelain tiles. The floor is concrete covered with vinyl. I plan to use the matching 3x12 bullnose tiles along the wall as a baseboard. The current baseboard is some sort of 4" wide vinyl strip glued to drywall.
1) Should I use the same thin set for the floor (Modified Mortar) to attach the tile baseboard, or would I be better off using a mastic (as if I was doing a backsplash)?
CountryBumkin is offline   Reply With Quote
Unread 11-13-2015, 12:46 PM   #2
jgleason
jgleason's Avatar
Hi Mike,
Since you will already have the thinset I would just use it. When you take off the vinyl strip that is there now you might end up having to do some drywall repair.
Unread 11-13-2015, 01:42 PM   #3
CountryBumkin
If the drywall paper pulls off at the bottom, do I need to do anything about it - or can I just put the bullnose tile over the drywall (as long as it covers the missing paper)?
Unread 11-13-2015, 01:47 PM   #4
Just remove any loose paper or mud before installing the tile.
Unread 12-09-2015, 03:25 AM   #5
Yutaka
any difference between using thin set or adhesive for tiling the baseboard?
any recommendation for adhesive?
Andy
Yutaka is offline   Reply With Quote
Unread 12-09-2015, 04:33 AM   #6
A decent thinset mortar will stick better, especially over the long term and in high moisture conditions.
Unread 12-09-2015, 09:42 AM   #7
Pirate
Are you removing the vinyl on the floor?
Randy
Pirate is offline   Reply With Quote
Unread 12-11-2015, 01:31 AM   #8
Yutaka
what about the premix one like Omni grip
are they better than regular thin set for baseboard?
Andy
Unread 12-11-2015, 10:23 AM   #9
See Post #6, Andy.
Unread 12-11-2015, 01:19 PM   #10
Yutaka
ok thanks
what about modify versa bound vs non modify premium plus
which one better on dry wall
Andy
Unread 12-11-2015, 01:21 PM   #11
I would use the VersaBond, but either should work just fine.
Unread 12-12-2015, 03:19 AM   #12
Yutaka
sorry not sure if i should ask here
what kinda caulking do you use on top of the tile baseboard
or there is other way to make it look better
Andy
Unread 12-12-2015, 05:44 AM   #13
Either find a caulk that matches the grout color, (most grout manufacturers have them), or fill the gap with painter's caulk and paint over it.
Thin Tiles/Porcelain "Sheets" John Bridge Professionals' Hangout 232 04-24-2017 06:13 AM
Transition from 1/2" Hardi to 1/2" drywall and the 1/16" difference?? Stainless169 Tile Forum/Advice Board 18 02-10-2014 08:32 PM
12x24 porcelain over 1/2" drywall "greenboard" Vojtech Tile Forum/Advice Board 3 06-21-2012 12:43 PM
Bullnose as a replacement for "regular" tile? tomharry Tile Forum/Advice Board 1 08-22-2011 11:50 AM
"Single Pass" Bullnose Profile Blade/Wheel for Honed Marble? fjordrr Tile Forum/Advice Board 17 10-18-2009 06:51 AM
