Unread 04-21-2013, 12:49 PM   #1
kezug
kezug's Avatar
Can I use Mapei Keracolor S Sanded Grout on Glass Mosaic tile
I have the following backsplash tile that is mostly glass with some stone tile intermixed. The lightest tile is the stone and the surface is smooth for all tiles pieces.
Can I use Mapei Keracolor S Sanded Grout on this type of tile? (or will it scratch the glass?)
The grout lines are 1/8".
You do it in one try - You're a genius
You have to do it more than once - You're an idiot
I am so close to becoming a genius!!!
Doug - from Northwest Indiana
Last edited by jgleason; 04-22-2013 at 04:38 PM. Reason: please use the paperclip icon to attach images
kezug is offline   Reply With Quote
Unread 04-21-2013, 02:11 PM   #2
cwilde72
cwilde72's Avatar
Best to do a test board with some leftover tile. Some glass will scratch while others won't. Better to find out on scraps rather then on installed tile.
Chad Wilde
Precision Tile
Huron, SD
cwilde72 is offline   Reply With Quote
Unread 04-21-2013, 04:54 PM   #3
jwmezzanotte
jwmezzanotte's Avatar
what chad said. mix some and test it.
I prefer sanded grout, so if it doesn't scratch that's what I go with
Sanded vs non-sanded on glass mosaic Calgary Dave Professionals' Hangout 13 04-08-2012 01:48 AM
Mapei Keranet / Keracolor Problem redscorpion Cleaning, Restoration and Sealing 2 07-06-2009 09:50 PM
Sanded or non-sanded grout for glass mosaic tiles? cdiwadkar Tile Forum/Advice Board 3 01-12-2006 10:20 PM
mapei terracota keracolor grout ?please mrjetskey Tile Forum/Advice Board 5 03-16-2005 07:02 PM
mapei terracota keracolor grout ?please mrjetskey Cleaning, Restoration and Sealing 4 03-16-2005 06:56 PM
