Unread 03-29-2013, 01:13 PM   #1
treesecup818@yahoo.com
treesecup818@yahoo.com's Avatar
diy, tile-able shower bench in a tub replacement Plank Pitch Shower Base
I'm new to this site, so sorry! I'm not sure if I'm using this site in the right way, but here it goes. I wanted to ask a question on a tile-able shower bench for my bathroom. We are putting in a tub replacement Plank Pitch shower base with a trench drain so we can tile with larger wood look plank tiles, what I need to know is, can we put a diy tile-able shower bench right on the tub replacement Plank Pitch Shower Base, like the ones on this site made with the Two-inch thick Kerdi-board?
Thank you,
Teresa
Teresa
treesecup818@yahoo.com is offline   Reply With Quote
Unread 03-29-2013, 01:50 PM   #2
e3
not sure if this is what your looking for..??
http://www.noblecompany.com/Portals/...ion%200109.pdf
Eric
Noble Company
Unread 03-29-2013, 01:58 PM   #3
Welcome, Teresa.
Some of that would depend upon what you intend for the waterproofing of your shower. The bench Eric linked could be used with most any waterproofing method, as could one made with materials such as KerdiBoard, but they'd all do better when using a direct bonded waterproofing membrane method, which seems to be what you have in mind.
Eric's Noble Company sells other materials for that, too.
Unread 03-29-2013, 02:36 PM   #4
Here are two picture that might help with my question
Thanks to both, Eric, & CX for your reply to my question...but here is 2 Pictures... , of what My Husband, & I wanted to do, DIY shower bench, “framed” with Kerdi-board in one of the the pictures I attached. Can we build a shower bench like the picture right on the shower base like the other picture I attached, of the pitch plank shower base with a trench drain?
Thanks again,
Teresa
Teresa
Unread 03-29-2013, 03:41 PM   #5
Hi Teresa,
You can build a bench like that only if you're drinking Negra Modelo.
Yes, you can build a Kerdi-board bench on the Tile-Redi floor. You can bond it there with thinset mortar or with one of the urethane adhesives like Kerdi-fix.
You will need to make a watertight transition between the Kerdi-board shower walls and the shower floor. Kerdi-band is one way. You can also use urethane adhesive/caulking.
The bench in your picture is from Tile Bathroom Remodeling by John Bridge.
Unread 03-29-2013, 03:50 PM   #6
Bodie Powers
Retired cabinet maker/remodeler
Bodie Powers's Avatar
Was it fun tiling up to that wavy bench pedestal? I bet without that Negro Modelo the pedestal comes out square
Bodie
Bodie Powers is offline   Reply With Quote
Unread 03-29-2013, 04:23 PM   #7
thank you John Bridge!
Thank you so much for your reply John Bridge, & yes the picture is from... John Bridge.com site, I love the bench in that picture, you do awesome work!, but we are thinking of doing a rectangle shape bench... which 1 side, & the back of the bench will be attached to the walls, the other side will be open, & tiled as will the front, & top of the bench. Hopefully its ok to leave the 1 side open, & tiled??
Thanks again!,
Teresa
Teresa
Unread 03-29-2013, 06:43 PM   #8
Of course. Any shape bench will work.
This is the bench during the course of construction. Tiling up to it (shower floor) took 80 man/hours (and several brewskies).
Unread 03-30-2013, 08:48 AM   #9
Hi John
That Shower is so beautiful, I seen pictures yesterday, somewhere online, of that entire bathroom & it was done, I'm sure it took a long time to do all of the work, but it was worth it... because it is breathtaking!
Teresa
Tile Replacement on Tub/Shower Surround cwtx Tile Forum/Advice Board 2 02-07-2008 10:14 AM
diy shower bench panic curlygirl Tile Forum/Advice Board 11 05-20-2007 01:22 PM
Shower Pan - mud pitch - and using Goof Proof Perfect Pitch... VAPeriodRestorations Tile Forum/Advice Board 7 04-20-2006 09:54 PM
diy-able tile shower base? dtom4 Tile Forum/Advice Board 8 09-06-2005 06:27 PM
diy projects -shower pan replacement maradri Tile Forum/Advice Board 2 02-16-2004 07:20 PM
