Unread 03-21-2013, 07:08 AM   #1
mark942
Forgot More Than I Know
mark942's Avatar
Metal Firebox
Hello
I have a 1980`s unfinished Heatilator that is in great shape for my basement Fireplace. No doors, No Blower. Just the box itself. No surround stone. No Mantle, No Hearth. No Doors. This was built in 1983 and is set in a cinder block surround with Brick tabs on the face. My question is, has any one here ever attached tile(Fire Brick) to the inside of one of these? If so, what was used to attach the Tile (Fire Brick) to the metal sides? I know heat will be a factor so glue is out. Mastic? Mortar? Screw in Wire and go from there? This is more for aesthetics, could some one chime in please?
Thank you.
mark942 is offline   Reply With Quote
Unread 03-21-2013, 09:59 AM   #2
Welcome, mark942. Please put a first name in a permanent signature line for us to use.
Do you plan to use this device as a wood-burning fireplace?
Unread 03-21-2013, 12:40 PM   #3
gsr
Hello Mark (?), here's a link to e-how Heatolator Brick Panel replacement: http://www.ehow.com/how_12216871_rep...fireplace.html
If you can't get replacement panels by contacting Heatolator, try snugly fitting fire brick with refractory mortar to fill the gaps.
Geoff
gsr is offline   Reply With Quote
Unread 03-23-2013, 03:08 PM   #4
mark942
mark942's Avatar
Thank you for the Welcome. Yes I do plan on usage.........But not as much as the wood stove on the first floor. As to listing my first name in a signature?? I tried and it doesnt seem to work....
Thank you Geoff for the link & recommendation.
Ledgestone veneer install (firebox is too tall) dglex Tile Forum/Advice Board 19 12-21-2012 10:36 PM
Firebox Paint mk636 Tile Forum/Advice Board 5 04-28-2009 07:07 PM
Tile around firebox Looking4ideas Tile Forum/Advice Board 2 12-28-2007 06:34 PM
Installing Stone Tile on Metal Firebox Surround Unregistered Tile Forum/Advice Board 31 05-01-2004 04:11 PM
Masonary firebox JohnF Professionals' Hangout 17 10-11-2002 07:01 AM
