Unread 01-06-2019, 06:38 PM   #1
nesc39
Miracle tiles!
Stuck these 2 colors of tile. Same exact brand that was bought at the same time and installed with the same mortar. The tiles have a white opaque backing on them to prevent seeing through to the mortar..... It’s been 2 days and I can see the mortar through the dark tiles and cannot figure out why. I just went and pulled off the tiles and they all still have the backing on them. Here are some pictures of the tiles on the wall and here is the exact same tile showing the front and the back
Repid
nesc39 is offline   Reply With Quote
Unread 01-06-2019, 07:05 PM   #2
Carbidetooth
Hmmmmm
Carbidetooth's Avatar
Many coatings on glass tile are opaque. Try sticking a damp sponge on the back of a new tile and see if the moisture is apparent from the front.
Manufacturers often are specific when it comes to mortar, which I'm assuming is what you're calling "cement". Most that I've used are almost super white and heavily modified. What did you use to bond them?
Peter
Unread 01-06-2019, 07:51 PM   #3
Radas
Tile Newbie
I second the white tacky mortar for glass. I've had pretty good luck with mapei's 10lb glass tile mortar.
Sent from my SM-G930P using Tapatalk
Ali
..a new excuse to hoard tools
Unread 01-06-2019, 08:38 PM   #4
nesc39
White TEC full flex. Use it all the time and never had this happen
Repid
Unread 01-06-2019, 09:22 PM   #5
workhurts
Any chance the lighter glass is also frosted? That could block the discoloration. Wonder if the darker glass would even out once everything is dry and cured.
Charlie
Unread 01-07-2019, 11:57 AM   #6
nesc39
No they are both clear glass. I made a mock-up test tile yestersay and that one looks fine, it’s so confusing
Repid
Unread 01-08-2019, 02:46 PM   #7
Lou_MA
You burned the backs of the tiles, plus notched and flattened the thinset to get 100% coverage?
Lou
Unread 01-12-2019, 07:45 PM   #8
nesc39
So the mock up with 1/2 of the tile spray painted turned out these results. Apparently the mortar is eating through whatever coating the company used. Also it only happens on the darker tile’s. Now ripping them all off and replacing them but Home Depot told the customer to beat it and they won’t pay labor to replace them
Repid
Unread 01-13-2019, 06:03 AM   #9
BelkTile
BelkTile's Avatar
That is so odd that it is eating the back of the tile coating.....
https://www.belktile.com
BelkTile is offline   Reply With Quote
It's a Miracle... oakview The Mud Box 3 05-02-2010 01:50 PM
miracle lati_cz The Mud Box 3 02-21-2010 12:56 PM
Miracle 511 H2O Plus blstrong Cleaning, Restoration and Sealing 1 04-08-2008 08:30 PM
