Don't think Custom Building Products would like the RedGard on plywood in a shower. You should call them. They allow it on a floor for decoupling, but then, it's not waterproofing.
If it were a simple curve like a cylinder, Kerdi or the KerdiBoard that is precut so it will bend probably would handle it, but don't know about a compound curve...never tried it. I suppose you could make additional cuts across the existing ones. Tiling, even with those smaller tiles on the curve might be challenging.
You could do this with one of the sheet membranes and waterproof the entire thing. You'd end up needing to make some cuts, and then the edges would overlap to follow the curve. When they weren't at least 2" overlap, you'd need to then band them.
But, not sure how much the exterior walls flex...my guess is that no tile would survive long-term, regardless of what you had underneath it. Fiberglass is sounding more viable, at least to me, and forget the tile.
