Unread 08-22-2017, 11:52 AM   #1
nelsonkoehn
showers & more
nelsonkoehn's Avatar
HardiBacker 500 4' x 8' Discontinued
So I've grown accustomed to using hardi in shower construction. Or I've learned to work with it nuances. And where I could I used 4x8 sheets. Now my builder supply yard says that James Hardi has stopped making that size. Of course I can still use the 3x5's, but after using the big ones, I find that I waste a lot more with the small sheets.
What are the options out there for 4x8 sheets of backer? Foam, fiber, or cement. I know I won't have anything stocked locally so I may need to just stock a lift myself.
Nelson
tile.nkoehn.com
nelsonkoehn is offline   Reply With Quote
Unread 08-22-2017, 01:43 PM   #2
Hi Nelson,
Hard to believe Hardi will quit making 44x8s. That's about all that is used on commercial projects. Anyway, I think all the rest make them.
Unread 08-22-2017, 04:17 PM   #3
Laticrete is coming out with 4x8 sheets of Hydroban Back Board at the end of the year.
In the mean time, their 3x5's are ~$20 at Daltile last I checked.
When Daltile got their first shipment I loaded 30 sheets at $15 a sheet.
Unread 08-22-2017, 06:05 PM   #4
Karls tile Inc
Tile and stone contractor Tile setter
Is it true with hydrogen you don't need washers on the screws?
Karl
Karlstile.com
Karls tile Inc is offline   Reply With Quote
Unread 08-22-2017, 06:35 PM   #5
Trying to fasten a gas with mechanical fasteners is gonna prove tricky.
Unread 08-22-2017, 07:38 PM   #6
yes this is true
Unread 08-23-2017, 02:32 AM   #7
tilemanct
Tile & Stone
You still have the option of 4 x 8 x 1/2" cement board. You also can try the USG Foam board. It comes in 4 x 8. No washers just cbu screws. Most of the setters around me have switched to it and are waiting for Laticrete to come out with their 4 x 8 foam board.
CTEF Certified Installer
Discontinued tile rontheriault Tile Forum/Advice Board 3 09-09-2014 01:13 PM
discontinued AO JimmyJohn Tile Forum/Advice Board 5 07-21-2010 01:21 PM
Looking for discontinued tile Melanie Mitchell Tile Forum/Advice Board 4 08-29-2009 04:13 PM
Looking for a discontinued tile sokoloff Tile Forum/Advice Board 3 12-21-2007 12:44 PM
