Unread 07-16-2017, 06:21 PM   #1
CaliGrown
CaliGrown's Avatar
Rounded corners
We wound up doing compound mitered corners. What is the better approach here?
Christopher Machado
1 (916) 990-1751
Unread 07-16-2017, 08:59 PM   #2
nelsonkoehn
showers & more
nelsonkoehn's Avatar
Looks beautiful
Nelson
tile.nkoehn.com
nelsonkoehn is offline   Reply With Quote
Unread 07-16-2017, 09:42 PM   #3
Topspin
SchluterUgrad
Topspin's Avatar
. . . Ask client if they really want rounded for tile portion, if not - un-round them. Other than that looks good
Unread 07-16-2017, 10:56 PM   #4
CaliGrown
CaliGrown's Avatar
Thanks. Client is happy with the corners.
What I meant was to ask what other ways are there to treat round corner beads?
Aside from putting on a right angle corner bead or doing a compound miter.
Christopher Machado
1 (916) 990-1751
Unread 07-17-2017, 05:50 AM   #5
Hi Chris,
I like the look of what you did, and I would probably do the same thing. The other way I can think of would be to locate quarter-rounds in that shade of stone. Lots of luck on that, though.
Unread 07-17-2017, 06:41 AM   #6
nelsonkoehn
showers & more
This is another way. But doesn't work very well with diagonal patterns.
Nelson
tile.nkoehn.com
Unread 07-17-2017, 03:41 PM   #7
CaliGrown
CaliGrown's Avatar
Thank you everyone. I like how that looks Nelson, with the offset continuing.
Christopher Machado
1 (916) 990-1751
Unread 07-18-2017, 03:37 AM   #8
tilemanct
Tile & Stone
So glad they don't use those rounded beads around me!! Both treatments look great. Lot of work in such a small area. Hope the customer appreciated your attention to detail.
CTEF Certified Installer
Unread 07-20-2017, 12:50 AM   #9
PetrH
one easy way to make it better is to use a belt sander to put a round over on your cuts, so your cuts look tumbled like the rest of the
Pencils in a matching stone work too, if you back bevel the tile for a tighter fit.
mosaic.http://www.johnbridge.com/vbulletin/...1&d=1500533381
Petr
How do i tile this rounded corner? catfell22 Tile Forum/Advice Board 3 10-16-2015 07:01 PM
Trying to tile around kitchen window where relief has rounded corners. sbidaho Tile Forum/Advice Board 6 08-23-2012 12:57 PM
Tiling around rounded corners AudioDesigns Tile Forum/Advice Board 15 02-20-2010 11:53 AM
Rounded corners at junction of shower floor and dam a problem? brigcorr@alaska.net Tile Forum/Advice Board 6 11-25-2005 08:00 PM
Rounded (bullnose) wall corners with ceramic tile baseboards....advice? SusieM Tile Forum/Advice Board 11 06-14-2003 07:05 PM
