Unread 03-29-2016, 12:38 PM   #1
vetting
Need a quick estimate/price check on a job
Just wanted a sanity check on a job in the Milwaukee area. I need a quote for the labor only separated out between the backsplash and bathroom.
Bathroom work
Diamond grind multiple high spots on basement floor
Lay plank tile
Grout and seal plank tile
Set shower pan in mason mix/cement
Cement board walls and ceiling
Tape/mortar seams
Multiple layers RedGuard
Install grey subway tile in vertical pattern
Custom cut niche during tile install to set niche inline with grout lines
Mosaic inset
Also the ceiling has tile
Grout and seal
Backsplash
Install backsplash - 18 ln feet on buffet area
Install backsplash - 10 ln fet in bar area
Cut around extra outlets 4 outlets buffet area - 3 outlets bar area
Grout
Just need a rough ballpark for the bathroom work and the backsplash. Thanks for the time!
vetting is offline   Reply With Quote
Unread 03-29-2016, 01:36 PM   #2
Looks like the work is already completed, Mike.
Unread 03-29-2016, 01:50 PM   #3
vetting
Yes, it would appear so
Just using this one as more of a gauge on if its worth it to get into the business officially or not.
Unread 03-29-2016, 01:54 PM   #4
That kind of price guessing is very, very locale and company specific, Mike. We don't have any idea where you are nor how you plan to structure your business. In generally, we recommend you determine just how much you need to gross per day of work to make a profit, then determine how many days you'll need to spend on the job and do the math.
Can be dramatically different for different areas and contractors.
[Edit] If you'll put that geographic location into your User Profile it'll appear permanently to help folks with their responses.
Unread 03-29-2016, 03:15 PM   #5
dhagin
You might be interested in this
http://www.johnbridge.com/vbulletin/...ad.php?t=15613
dana
Unread 03-29-2016, 04:30 PM   #6
rmckee84
rmckee84's Avatar
Ballpark, bathroom $3500-4500
Backsplash $500-700
Ryan McKee
Unread 03-29-2016, 04:36 PM   #7
nelsonkoehn
showers & more
nelsonkoehn's Avatar
Ballpark, bathroom $8000-12000
Backsplash $1000-1500
Nelson
tile.nkoehn.com
nelsonkoehn is offline   Reply With Quote
Unread 03-29-2016, 04:55 PM   #8
Cain
Cain
One million dollars.
Or whatever you need to make a living + materials+profit
Cain Curtis
A Tile Experience
Certified Tile Installer #362
Cain is offline   Reply With Quote
Unread 03-29-2016, 06:09 PM   #9
evan1968
Not So Senior Contributor
evan1968's Avatar
Tree fiddy...ballpark.
Craig
Commercial Tile Installations
KEEP CALM and TILE ON
Unread 03-29-2016, 06:20 PM   #10
HS345
Tile Contractor
HS345's Avatar
You win. [/thread]
The name's Greg
Unread 03-29-2016, 06:35 PM   #11
Chad Deiter Company
Making Cents of It All
Chad Deiter Company's Avatar
Send a message via Yahoo to Chad Deiter Company
It's amazing the price ranges state to state.
Chad from CDC54.com " You Dream It and We Create It "
Southern California Custom Tile and Stone Installation
Chad Deiter Company is offline   Reply With Quote
Unread 03-29-2016, 10:08 PM   #12
vetting
This is what I came up with for labor only.
Entire bathroom area
$2,075
Back splash (both areas)
$515
Unread 03-29-2016, 11:27 PM   #13
evan1968
evan1968's Avatar
Mike,
How long(hours) did those areas take to complete?
Craig
Unread 03-30-2016, 04:41 AM   #14
tilemanct
Tile & Stone
Enjoy living in your van down by the river.
CTEF Certified Installer
Unread 03-30-2016, 07:36 AM   #15
Dave Gobis
da Man!
Dave Gobis's Avatar
I would be double that on the backsplash and a third higher on the bathroom roughly speaking. That would make it a wage job, not a big money maker. If I was busy double or better on both.
Price estimate qofmiwok Tile Forum/Advice Board 28 06-22-2014 06:26 PM
Check out this price figaro Professionals' Hangout 32 09-24-2009 08:55 AM
Kitchen Floor check, cabinets check, counter top........ bbenkaz Tile Forum/Advice Board 6 12-04-2006 08:53 AM
quick question about thinset...need answer quick agoings Tile Forum/Advice Board 13 04-28-2006 06:19 AM
A quick hello and a quick question of tile and stairs. bmkiss67 Tile Forum/Advice Board 14 07-30-2003 09:09 AM
