Unread 11-24-2020, 05:03 PM   #16
40 psi max.
Unread 11-24-2020, 08:53 PM   #17
SME1225
Well this is a nightmare. I did the flood test (8 hrs only because I didn’t want it in the drain while I slept) and this is what I found when I lifted the pan liner. And all of that water amounted to just over 1/8 of an inch loss of water level. I was happy with the results of the test until I saw below the liner!
So now I have to approach the worker. Can I let it dry out and just replace the pan liner (properly this time)? Any further advice for me?
Shannon
SME1225 is offline   Reply With Quote
Unread 11-26-2020, 08:50 AM   #18
Bummer, Shannon.
But yes, remove the liner and let the mud bed dry out completely. If you're careful with removing the liner, especially at the drain connection, you might be able to determine what the issue was.
Unread 11-26-2020, 08:53 AM   #19
For the plug, I use an emergency car tire inflator. I think the max pressure is 40psi, which someone already stated. However, when you pull the pump off of the inflation tube you lose some air. A lot of times, too much air.
So this is a long way of saying that I usually inflate it up to about 47lb and then pull the pump off. Additionally, I always pull up on the hose to make sure the plug is snug in the pipe.
Next issue: water under the liner.
I'm not sure where we're at with this anymore. Did they replace the liner after the silicone incident? Have they made any cuts with the liner that aren't the drain hole and the 4 bolts around it (such as the curb or corners)?
What you might do is replug it and add water to just barely cover the drain and then see if that holds. If it does, then we've ruled one culprit out.
James Upton
Unread 12-08-2020, 03:38 PM   #20
SME1225
Penny tile layout
Hello. I had this mosaic penny tile laid today...thinset is done but it has not yet been grouted. Is it possible to make changes now? For some reason the mosaic sheet in the far right back of the shower has a lot of dark tiles and the one just in front of that has no dark tiles. Can they pop out some tiles and exchange them for new ones tomorrow or totally rip those sheets up and set new ones without any issues? Or is it too late to make changes?
Shannon
Unread 12-08-2020, 03:41 PM   #21
SME1225
Shannon
Unread 12-08-2020, 03:47 PM   #22
They should be able to remove some of those tiles from your mud bed, but the sooner the better.
Unread 12-10-2020, 08:43 AM   #23
Ronman
Registered LUser
Curious if they got those drain and liner issues fixed up, Shannon?
Ron
Ronman is offline   Reply With Quote
USG shower system flood test - fail? renue74 Tile Forum/Advice Board 12 12-09-2017 05:08 PM
mudded shower pan flood test? reman3 Tile Forum/Advice Board 9 10-31-2013 10:14 PM
Flood test on Schluter shower??? bc brick john Professionals' Hangout 7 04-19-2013 08:12 PM
Flood test for barrier free shower/wet room kellykungfu Tile Forum/Advice Board 20 03-12-2010 01:33 AM
need help with my flood test for shower pan please :) FemmeMetale Tile Forum/Advice Board 4 01-15-2010 03:53 PM
