Unread 09-03-2011, 09:08 PM   #1
nelsonkoehn
showers & more
nelsonkoehn's Avatar
Layout question
Okay, I messed a layout up and I need some advice on what to do about it. 3x6 tile so not a lot of up and down to move, hit my tub edge right,
Name:  Tapeji Gold 042.jpg
floor right, up against plug couldn't go higher,
Name:  Tapeji Gold 043.jpg
couldn't go low enough because demo left marks on walls that needed to be covered by install. Now I have a wedge cut left against the ceiling.
Name:  Tapeji Gold 040.jpg
Name:  Tapeji Gold 036.jpg
What can I do to finish this, and what should I do different next time?
Nelson
tile.nkoehn.com
Unread 09-03-2011, 09:11 PM   #2
nelsonkoehn
showers & more
Oops, forgot the incriminating one
Name:  Tapeji Gold 039.jpg
Top row runs from 3/4" to less than 1/4"
Nelson
tile.nkoehn.com
Unread 09-03-2011, 10:48 PM   #3
tuckertile
tuckertile
NELSON..what's wrong with the first pic? i don't see a layout problem in first pik?
"you too"!
tuckertile is offline   Reply With Quote
Unread 09-03-2011, 10:52 PM   #4
tuckertile
tuckertile
o.k..... you wanted fulls and halves along left tub edge and looks like you gonna have small cut's,not much you can do kinda married to it ...unless you do a soldier course like you did in other piks.......
"you too"!
Unread 09-04-2011, 06:49 AM   #5
nelsonkoehn
showers & more
Everything else worked out great other than the cuts against the ceiling, and the ceiling is unlevel. I said the cuts were from 3/4 to 1/4 but I don't think that I can even get a piece into the back corner, so the top row could disappear into nothing. I guess that is my only option. Just makes the tile job look bad when things don't line up, square up, with existing boundaries. Would have liked more than 1/2 tile so wedge cuts don't show.
Nelson
tile.nkoehn.com
Unread 09-04-2011, 08:20 AM   #6
jondon
jondon's Avatar
Nelson, avoiding this would have taken proper planning. Measuring how you were doing to do you layout so you didn't end up at the ceiling like you did. In doing layouts with people I tell them, I want to know how everything is going to look before I actually do the installation. Small pieces that aren't even the same are going to take the good from your job. Everyone is going to be saying, "wtf happened up there at the ceiling?"
Depends on how much you are willing to do to get it right. You could drop the ceiling and make sure it is level. Take away that gap. You could go over the existing drywall with new drywall, shim it in the process and make it level, you wouldn't have to remove the existing piece.
I would say use some kind of wood trim up there, but it won't look right if the ceiling isn't level. Maybe you could shim it to make it look level and use some caulk to filled in area. Dunno, just an option if you don't want to drop the ceiling or pull tile off the wall.
This job is an example of no planning ahead. You never want to start tiling and just see what is there when you get there. I little adjusting at the first row could have prevented this. You don't have to have a full piece there though it looks good when you do.
Jon Donmoyer
JD Tile
CTEF Certified Installer #825
Unread 09-04-2011, 09:23 AM   #7
If it bothers you too much, tile the ceiling just over the tub area.
Unread 09-05-2011, 06:52 AM   #8
nelsonkoehn
showers & more
I know this did not turn out right and it is my fault, but it is not entirely because of no planning ahead. I guess one of my questions is can you get every layout to come out some hows? I had the floor, tub edge, countertop, plugin, a bullnose on top of the walls beside the tub, window bottom, window top, mirror and the ceiling to hit on the horizontal lines. And like I side the tiles are only 3" tall, so not a lot of moving the layout up or down. Everything else did come out right, but I did not check the ceiling for level and that is what got me into trouble. Anyways this is what I ended up with and I am as disappointed, or more, than anyone else. Looking back I should have caught this, but then again looking back I don't know what I could have done differently.
This is the rest of the room
Name:  Tapeji Gold 029.jpg
Name:  Tapeji Gold 030.jpg
Nelson
tile.nkoehn.com
Unread 09-05-2011, 07:25 AM   #9
If the ceiling is out of level, you can bed it out with more mud. It will take several layers but I have done it before.
Unread 09-05-2011, 09:51 AM   #10
I would install crown molding, to hide that gap.
Unread 09-05-2011, 10:16 AM   #11
tuckertile
tuckertile
i would put 1/2" hardi on the ceiling, tile it , and continue that radius mud cap along the front....
"you too"!
Unread 09-05-2011, 07:55 PM   #12
nelsonkoehn
showers & more
I like this idea the best, I'll run it past the HO and see if it flies, hafta order more radius cap tile, sigh!!!, stretch this job out longer, Ohh well!!!!
Nelson
tile.nkoehn.com
Unread 09-06-2011, 10:35 PM   #13
RedRock
Granite, Quartz, and Tile Installer
RedRock's Avatar
Just chalk this one up as experience. Learn from your mistakes and move on. You'll never make that mistake again and will do better next time. There are certainly many folks on this forum who have a few disappointments in their work. I'll be first to admit to have a closet full of them.
Juan
__________________________
You are never too old to set another goal or to dream a new dream. - C. S. Lewis
RedRock is offline   Reply With Quote
Unread 11-26-2011, 08:49 AM   #14
nelsonkoehn
showers & more
Here is the finished pic of the fix to the layout.
Name:  Tapeji Gold 054.jpg
This job is now completed, and almost forgotten!
Nelson
tile.nkoehn.com
Unread 11-26-2011, 09:16 AM   #15
doitright
doitright's Avatar
Hi Nelson
Thanks for the update on that project.
Tiling the ceiling was the way to go!
Looks like all they're doing is drinking coffee in there.
John Koessler
Layout question Geewiz Tile Forum/Advice Board 2 05-31-2008 07:03 AM
Layout Question scoutone_73 Tile Forum/Advice Board 2 02-04-2008 07:16 PM
Layout question SeanC Tile Forum/Advice Board 5 12-01-2007 09:56 PM
Layout Question Details Tile Forum/Advice Board 4 02-05-2006 01:35 PM
layout question, HELP!! bigblock396ss Tile Forum/Advice Board 10 02-09-2005 04:56 PM
