Hi y'all. Been lurking for a few weeks getting ready to install a back splash in my kitchen. I recently had granite installed and removed my old laminate. The installers did a fairly good job. I have an L shaped kitchen with 2 walls being tiled. The main wall with stove is 9' and an adjacent 5' wall. The entire 9' wall is leveled perfectly. I have a sink set at a 45 and the old counter tops did not have enough support in that area so they built a bunch of supports and really leveled everything up for me. when I turn the corner on the 5' wall it appears to drop off about 1/4" over 5feet. I know it's the cabinets that aren't set correctly. The installer shimmed the front of the granite a bit. but I don't know if it is acceptable to shim it even more in the back. Do I:
1. Call the installer and have him re-shim the slab?
2. just run the first row along the un-leveled surface and correct under the cabinets?
3. Set the first row at the lowest point and shave down the tile as it goes?
4. something else?
I have chosen a 3x6 honed filled travertine tile set with a 3 row mosaic above the first row of subways. I know some DIY folk would just "figure it out" as they go. Unfortunately for me everything needs to be "perfect" before I even start buying thinset.
Don't ask my wife about how long it took me to figure out how to run electric for under cabinet lighting
If I even say Xenon around her she'll kick me. And don't think for a minute that after I installed the lights she didn't say: Are you supposed to see that wire!!!
Thanks in advance
