Unread 09-18-2011, 12:10 PM   #1
jbaskins16
Kerdi Board Curb Question
I just had a complete kerdi shower installed and it looks absolutely great. The curb of the shower was constructed using two 2" thick pieces of kerdi board. After the shower was completed and tiled, I had a semi-frameless glass enclosure installed. I instructed them to glue the bottom frame to the curb, which they did, but drilled 2 holes into the tile/kerdi board shower curb to insert anchors in order to mount the door bracket. I know this is not the preferred method but too late now.
I'm worried about water leaking through those 2 screw holes. The glass installer said that he put silicone in the holes when the anchors were put in, but I'm not sure I believe him because it doesn't look like it. Given that the kerdi board used was thick (each piece 2 inches thick), I know that the screws did not penetrate all the way though. From what I read, Kerdi Board is made from EPS foam which in theory shouldn't leak. No signs of leaks so far, but should I be concerned with this? I'm nervous because every thing I have read says not to screw into the curb.
John
jbaskins16 is offline   Reply With Quote
Unread 09-18-2011, 02:16 PM   #2
Lazarus
Lazarus's Avatar
John, you're right. You shouldn't screw into a curb. Having said that...if you absolutely MUST, Kerdi Board is the stuff to screw into. Do you trust that he actually used silicone in the screw holes? If so, you are probably OK.
You might want some sort of written assurance from him that, if it leaks as a result of his actions, he will repair it.
Laz...
Unread 09-18-2011, 07:50 PM   #3
The foam part of the lerdi board is the waterproof part. As long as they didn't drill all the way through the foam to the other side you should be fine. The screw, molly plug, and silicone should fill the hole and prevent any water buildup. I'd bet against it leaking.
Kerdi shower curb question rar548 Tile Forum/Advice Board 2 11-03-2007 06:10 PM
A shower curb with cement board and Kerdi trihai Tile Forum/Advice Board 4 04-30-2007 01:41 PM
Kerdi Curb Question Kungur Tile Forum/Advice Board 4 01-27-2006 09:49 AM
Kerdi curb question zinkarawana Tile Forum/Advice Board 2 11-09-2005 06:51 PM
Kerdi shower curb question zinkarawana Tile Forum/Advice Board 4 09-09-2005 04:39 PM
