Welcome, Matt.
Originally Posted by Matt
engineered joists spanning 16'oc and the length are 20'.
I'm gonna presume you mean your engineered joists are spanning 20 feet and are installed on 16-inch centers. Only way to determine the deflection of that joist system is to consult the manufacturer or his online published span tables.
But it's generally safe to assume the structure was engineered to at least the code-required L/360 and with a span that long almost as safe to presume it was designed to L/480.
Presuming further that you intend to use ceramic tile, your joist structure is adequate.
The 3/4" subflooring, properly installed, meets the minimum requirements for either Hardibacker or Ditra. Which you elect to use is up to you, but removing the Hardi at this point leaves you with damaged subflooring upon which to install your Ditra. I'd want another layer of plywood over such subflooring, but, then, I'd want another layer of plywood over any single-layer subfloor.
So. Presuming your Hardibacker has been installed per manufacturer's instructions, unless you're prepared to remove the Hardi, properly clean your subfloor of all the remaining thinset mortar from the Hardi installation, and install another layer of plywood, I'd just tile over what you have.
