Unread 11-16-2010, 01:20 PM   #1
GarryS
Sealing escutcheon plates
Hello everyone ,and thanks for all the great information posted here. As I complete my shower install I need to ask a question about escutcheon plates. And/or the openings in my ceramic tile where the copper pipes extrude. I have seen different opinions on the subject and was wondering if some of the pros here would mind offering their ideas and/or tips on this subject. My shower is not a steam shower, just a normal ceramic tile shower.I have 3 holes in my tile, one for the head, one for the main valve control and one lower hole for a tub spout my wife wanted (about a foot off the floor). My question is: should I silicone the pipes where they extrude from the wall? or should I silicone the escutcheon plates themselves? I've also read that some use plumbers putty behind the plates , but then again ,some don’t use anything and say the plates are enough. Thanks for all your help.
Garry
GarryS is offline   Reply With Quote
Unread 11-16-2010, 01:28 PM   #2
Garry,
100% silicone, like this;
No silicone needed around the escutcheon plate
Unread 11-16-2010, 02:12 PM   #3
GarryS
Thanks Paul. How would you seal the water control valve opening/and or plate ? It would have to be different due to the screws that go through the plate then into the valve.
Garry
Unread 11-16-2010, 04:53 PM   #4
lasvegaslenny
Desert Dweller
lasvegaslenny's Avatar
Gary I usually run a bead of 100% clear silicone around the valve trim plate as I dont trust the foam/rubber seal that comes from the manufacturer.
Lenny Ambrosino
Master Built Construction
www.MasterBuiltLasVegas.com
"We are born to action; and whatever is capable of suggesting and guiding action has power over us from the first." -Charles Horton Cooley
lasvegaslenny is offline   Reply With Quote
Unread 11-16-2010, 06:51 PM   #5
I like the Kerdi Seal PS & MV Seals that come with the Kerdi drain.
on the mixing valve it has a slight slope back into the shower
so if any tiny bit of water gets there it runs back out.
Last edited by cx; 12-17-2011 at 10:35 AM. Reason: Correct typo at owner's request
Unread 11-16-2010, 08:09 PM   #6
silvercitytile
silvercitytile's Avatar
yeah thats what i love about kerdi drains
Castillo Construction
Unread 11-17-2010, 09:24 AM   #7
WendyHMN
Amateur Jack of All Trades
WendyHMN's Avatar
Brian, are you applying the seals with kerdifix? I would think thinset would be much more economical.
Wendy
Unread 11-17-2010, 11:04 AM   #8
Lazarus
Lazarus's Avatar
I would think KerdiFix would be overkill, but certainly would be great. I generally use the DitraSet to seal 'em.
Laz...
Stone switch plates crg Tile Forum/Advice Board 6 11-12-2008 07:19 PM
Tile under switch plates/outlets help please coffeecup44 Tile Forum/Advice Board 11 01-14-2008 06:29 AM
Tile under or around escutcheon? Novice92 Tile Forum/Advice Board 1 11-04-2006 10:24 AM
Sealing shower valve and escutcheon ESM Tile Forum/Advice Board 5 01-30-2005 05:05 PM
Notching and Boring Wall Plates MIT Tile Forum/Advice Board 2 02-25-2004 10:03 AM
