Unread 11-02-2010, 08:35 PM   #1
MVWood
1st ditra install
I am going to try my first ditra install tomorrow for a kitchen floor. The tiles are 13". The sub-floor is 3/4 ply with 3/8 ply nailed over top. The joists are 2x10, 16"oc, 11' span. I will be purchasing all my material from the Home Depot so my question is which morter for under the ditra and which for over the ditra?
Scott
Mountain View Woodworking Inc.
Certified Lead Safe Contractor
MVWood is offline   Reply With Quote
Unread 11-02-2010, 08:42 PM   #2
Edthedawg
Edthedawg's Avatar
Hi Scott,
Ditra is modified below if bonding to plywood, and unmodified above.
Homers doesn't sell a good unmodified, so swapping in a lightly modified thinset like Versabond is frequently done without a problem. It works below, as well, tho you could spend more for the exact same result with a different thinset.
Ed
GO SOX!
Unread 11-02-2010, 09:01 PM   #3
Levi the Tile Guy
Tile and Stone Contractor
Levi the Tile Guy's Avatar
Just make sure you get good coverage under your ditra. I have seen a number or ditra jobs go bad just because people didn't get their corners down good, and that ended up giving the rest of it issues also.
Levi The Tile Guy
Unread 11-02-2010, 09:11 PM   #4
MVWood
So Ed you think I could use vera on top and bottom? I do have a local tile store that I could check for other non modified. There is also a Lowes in town
Scott
Unread 11-02-2010, 09:18 PM   #5
Levi the Tile Guy
Scott if you have a lowes I would pick up some kerabond for the top. Kerabod is a pretty good dry set and it's not to badly priced. Versabond will work under just fine, or if you want to get thinset for both from lowes use Ultraflex 2 for the bottom.
Levi The Tile Guy
Unread 11-02-2010, 09:21 PM   #6
silvercitytile
silvercitytile's Avatar
what size trowel are u planing to use Scott?
Castillo Construction
Unread 11-02-2010, 09:27 PM   #7
MVWood
Thanks Levi. I'm not sure I've ever seen kerabond at lowes but I will check tomorrow.
Jeff I was going to go with 3/16 v notch
Scott
Unread 11-02-2010, 09:29 PM   #8
silvercitytile
if u can find a 1/8 square notch u'll get better coverage
Unread 11-02-2010, 09:40 PM   #9
Edthedawg
Edthedawg's Avatar
Versabond above and below doesn't technically meet the mfr specs, but it's been thoroughly field-tested to my satisfaction as a perfectly acceptable thinset mortar for use both above and below Ditra.
Ed
GO SOX!
Unread 11-02-2010, 09:50 PM   #10
Levi the Tile Guy
If your Lowes doesn't have kerabond then it probably carries Laticrete which would be 317 or 211 I think (laticrete not readily available for me around here) but if they cary Mapei they will have kerabond
Levi The Tile Guy
Unread 11-02-2010, 10:51 PM   #11
you can get a 1/8" square notch in the linoleum section of Home burrito. they are black handled
Unread 11-02-2010, 11:16 PM   #12
silvercitytile
thanks Pual
Unread 11-03-2010, 12:37 AM   #13
Typically (at least in this area) Lowe's stocks Laticrete Multipurpose as a modified and Laticrete Megabond as unmodified - OR - Mapei Ultraflex 1 & 2 as modified and Mapei Keraset as unmodified.
You might find something differently at your store, but that gives you an idea of what to look for. Stay away from the Kerafloor if you happen to run across it. It's a lower-end unmodified.
Kitchen Floor Install for a 1st Timer tommyk Tile Forum/Advice Board 2 10-24-2008 10:20 PM
1st timer on Kerdi Shower install duraleigh Tile Forum/Advice Board 41 09-27-2008 09:37 AM
1st ever Kerdi, Ditra install tilelayer Professionals' Hangout 7 06-11-2007 11:47 AM
1" hex tiles,1st time install jim k Tile Forum/Advice Board 7 04-20-2006 09:43 AM
1st time Ditra user Litefoot Tile Forum/Advice Board 10 04-11-2006 10:28 AM
