Unread 01-13-2010, 02:24 PM   #1
jondon
jondon's Avatar
proper roofing nails for cbu
I know this has probably been discussed but don't feel like trying to weed through everything to find an answer. What are the proper roofing nails to use when fastening cbu such as Utilicrete, cement board not fiber board. And.... are these nails available to use with a roof nailing gun? The only nails to go with the guns I saw were galvonized. thanks!
Jon Donmoyer
JD Tile
CTEF Certified Installer #825
Unread 01-13-2010, 02:50 PM   #2
CSS
CSS's Avatar
http://www.fastenerusa.com/products_c174939.html
hot dipped galv is what i use.
Robo
www.webspawner.com/users/premiumtileguy
CSS is offline   Reply With Quote
Unread 01-13-2010, 03:24 PM   #3
astrojeff
I was wondering the same thing a few years ago. Here's the discussion:
http://www.johnbridge.com/vbulletin/...ighlight=nails
Of course, I could not find hot dipped galvanized roofing nails at any one of the 20 or so hardware stores around here, so I finally gave up and went with paying a couple dollars more per sheet for the CBU screws. I'm sure you can order them if you can't find them either, but good luck!
-Jeff
astrojeff is offline   Reply With Quote
Unread 01-13-2010, 07:31 PM   #4
Billy12
I've had trouble finding these as well. Because i don't have a roofing gun i've been looking for a box of them with no luck what so ever. Someone here suggested going to a store like Ace or Hardware Hank but they don't have them either. Couldn't even find them online.
Billy12 is offline   Reply With Quote
roofing nails david nicko Tile Forum/Advice Board 8 09-17-2009 04:09 AM
roofing felt + CBU? Wrenn Tile Forum/Advice Board 21 12-15-2007 11:55 PM
Proper screws (or nails) for subfloor???? sean riha Tile Forum/Advice Board 1 08-22-2006 02:22 PM
Hot Dipped Galvanized Roofing Nails ewstan Tile Forum/Advice Board 3 01-19-2005 05:14 PM
Galvanized Roofing Nails Edem Tile Forum/Advice Board 10 12-08-2003 12:18 AM
