01-07-2010, 02:54 PM
Doug's Bathroom Transformation...I Need Help
Hi there. I am new to this site and this is my first post. I am wanting to take out vinyl in my bathroom and put in ceramic tile. When I removed the vanity I could see there is some sort of 1/4" backer board under the lino. I chipped a piece off and took it to Home Depot and Rona and nobody could identify it. Not hardibacker or K board or anything else they were familiar with, but similar. The surface is fairly hard, and the middle is crumbly - like a fibrous drywall with a harder surface. Whatever it is - it's stapled to the subfloor every 2-3 inches around the perimeter and approx. every 6 inch in the middle. It is also glued to the subfloor but no thinset. I need to remove it as there is some sort of divot/dip in the middle of the floor, and this mystery board does not cover the whole floor anyway. I intend to replace it with new 1/4" wonderboard (thinset + screws as per manufacturers recommendations of course!) before tiling. The trouble is how to identify it and make sure it does not contain asbestos or anything hazardous, and then how to best remove it. I tried scraping the lino off so I could get at the staples, but that did not work too well, and the board would still be glued down anyway. Home Depot suggesting ripping it piece by piece with a pry bar. The house was built new in 1993.
dlavis
01-07-2010, 03:25 PM
Welcome Dlavis
It sounds like particle board, but regardless it does need to come up. Then you need to make sure the subfloor underneath will be adequate for your tiling plans.
First you need to get it up. It may come up easy or not so easy depending on how well it's glued. Set your saw to cut through the depth of the underlayment only and make a series of grid style cuts (safety glasses, dust mask, and try to avoid cutting the staples) and work each area with a flat bar, chisel, etc. until you have removed all the particle board. Then report back with some pictures, or sooner if you have additional questions during the demolition.
01-07-2010, 03:53 PM
Shawn, thanks for your quick reply! It is definetely not particle board, as it is not wood - it is like a cement board type of product, which is why I was concerned about asbestos since nobody could identify what type of board it actually is. But I am told since my house was built in 1993 there is zero chance it is an asbestos containing product. I just wanted to try and verify. I will take pictures when I can and post them. Thanks again!
dlavis
01-07-2010, 04:11 PM
I agree about the asbestos not being in it unless they saved from many years before it to use on your house  Interesting it's not PB or ply. How easily does it break up? What color is it?
01-07-2010, 04:18 PM
Breaks up very easily between the staples, with the exception of where it is glued down. Surface is a grey color, and the crumbly middle is white. It looks very much drywall, and even snaps like it, except is has quite a hard top surface. I'm working on the premise that if it was a regular cement backing board you would think someone at Home Depot or Rona would have recognised it. The bottom seems to have a slight shallow corrugation to it. I tried a small cut with the circular saw last night and it makes a lot of super fine white dust.
dlavis
01-07-2010, 04:22 PM
Okay, it's fiber reinforced gypsum. Should come up fairly easily.
Have a shop vac with a good filter and you or someone to hold it near the saw to catch most of that dust as you cut.
01-11-2010, 07:01 PM
Moving on to the next step!
I managed (with a jack hammer held at a shallow angle to the floor, a wide spade attachment, a whole day and a LOT of effort) to get the fibre reinforced gypsum, staples, and most of the glue up from the plywood floor. Naturally, in the process, I put a few healthy gouges in the plywood. Should I fill these gouges in with some thin set to "level" the floor, let it cure for 24 hours, and then do a whole layer of thin set mortar for placing the wonderboard underlay? Or should I do it all in one step and assume the thin set will just fill in the gouges? They are localised, and the deepest is probably 1/4 - 3/8" deep. Or should I use a different product to fill in the gouges in the plywood?
dlavis
01-11-2010, 08:17 PM
New England Tile Man
Just fill the low spots with thinset the same day you prep the floor.Once you spread more thinset for the wonderboard the low spots will be taken care of.
Michael
01-19-2010, 09:24 PM
Set my first ever tiles tonight but had problems with them moving around too easily!
Hi there. I am a newbie, laying my first tiles for a bathroom floor. I mixed the thin set as per the instructions on the bag and until I thought it was the proper consistency (like peanut butter). I slightly dampened the wonderboard, spread the thin set out for four tiles (I had previously laid out lines for squares of 4 tiles), combed it at a 45-degree angle with the recommended trowel notch size, slightly dampened the back of the tile, buttered the back of the tile with a thin layer of thin set, and then placed the tile. The problem is, once I set additional tiles around, and tried to use spacers and line them up with my lines, they slid so easily on the thin set that I had to keep re-adjusting each tile. They moved very easily - even though it was only 1/8" to 1/4", it was enough to mess things up, and because I had spacers in there, when one moved, the adjacent one moved too. I tried to tap them into the thin set with a rubber mallet and wood, but they moved each time. I also had lots of thin set squish out the sides, and because I'm new at this, I got lots of thin set on the top of the tiles as well. Every time I tried to clean the top of the tiles, they moved around from the pressure. My question is, too much thin set, or wrong consistency, or something else? When I put the tile in, should I feel it make contact with the wonderboard, or is it completely supported on thin set? Any advice would be greatly recommended before I continue tomorrow night!! Thanks so much.
dlavis
01-19-2010, 09:25 PM
Thanks for the advice. I really appreciate it!
dlavis
01-19-2010, 09:30 PM
your trowel notch is either too deep or your thinset is a little too loose,
I'm going with a combination of both.
01-19-2010, 09:33 PM
Thanks caramictec. The trowel notches are the recommended size, so must be the thinset. By too loose, do you mean not enough powder / too much water? i.e. I should make it thicker?
dlavis
dlavis,
What size trowel and what are the tile dimensions? Ceramic tile? You shouldn't be wetting the backs of the tile IMO. You probably don't even need to backbutter them. Burning the backs would probably be sufficient. By the sounds of tile sliding all over and thinset on the top of the tile I think you have too much thinset down. Since you are new did you try mixing the thinset according to the manufacturer's instructions?
Edit: A classic example of why we want all project questions on one thread. Background information readily available on original post. We can change the title to something more fitting of the overall project. Please ask all your project questions on this thread.
01-19-2010, 09:40 PM
Brian, the tiles are 12x12 and 1/4" thick, porcelain. They have a cross-hatch grid of ridges on the back - not sure if all tiles do or not? The trowel notches are 1/4" x 1/4". Because I was only laying a few tiles I could not mix the whole bag of thinset to the proportions recommended, so I just tried to get a peanut butter consistency as recommended by a buddy. But I did follow the directions of mixing for 5 minutes, waiting for 10, and then mixing for 2 more. What does burning the backs mean?
dlavis
01-19-2010, 09:46 PM
#15
Burning the backs is to trowel a very thin coat of thinset with the flat side of your trowel...just enough to skim those "cavities". Your trowel size sounds about right. I think you may have too much or too loose thinset like Brian (Ceramictec) said.
