Unread 05-28-2009, 12:22 PM   #1
canoerat
tile inlay on wood
I'd like to inlay 2 strips of 1 inch slate tile as a skid strip into stair treads made of 2x12 ipe (ironwood). I'm hoping to get away with using a flexbond thinset but I would think the grout would crack. Any suggestions?
Mary
canoerat is offline   Reply With Quote
Unread 05-28-2009, 12:23 PM   #2
canoerat
tile inlay on concrete with bamboo
I'd like to do a similar skid strip surrounded by glue down bamboo on a concrete slab. Suggestions for thin set and grout there?
Mary
Unread 05-28-2009, 12:57 PM   #3
I think you'd have problems getting that to work. Epoxy could be used to glue the stone to the wood, and it might hold for a while. You'd have to use a caulk instead of grout.
Unread 05-28-2009, 01:02 PM   #4
If I were tryin' to do that, Mary, I would afix my stone pieces to the Ipe with Schluter's Kerdi Fix and use a flexible sealant of some sort in lieu of grout, as Injineer Bob suggests.
I haven't found a lot of things that stick well to Ipe, but I've never tried any thinset mortars. Would not have high hopes for even the super-modified ones, though.
Unread 06-01-2009, 03:44 PM   #5
canoerat
What about the the inlay of the tile onto concrete slab surrounded by bamboo? I'm assuming I shouldn't let the bamboo guys glue it down with their stuff but should use a highly modified thinset with grout between the tiles and caulk between the tiles and the bamboo. Sound kinda OK?
Mary
Unread 06-01-2009, 10:45 PM   #6
dhagin
Looks good, but I'd worry less about 'highly' modified and use a good medium bed so you could adjust the height easier - slate it heavy. For ceramic, a good modified will be fine.
dana
glass tile inlay JoeC Professionals' Hangout 5 06-24-2007 09:57 PM
How to fix 80mm wood inlay into tumbled travertine rushers Tile Forum/Advice Board 7 09-08-2005 05:44 PM
granite inlay get level Tile Forum/Advice Board 2 03-31-2005 10:01 AM
Glass Mosaic Inlay on Wood/Masonite Door fineline Professionals' Hangout 8 12-23-2004 08:03 AM
wood inlay against tile skyshark Tile Forum/Advice Board 2 09-28-2004 07:13 AM
