Turning a jacuzzi tub into a tub/shower
Any help would be greatly appreciated as I am in way over my head.
I have a 6' jacuzzi tub which has ceramic tile all around it and up the wall about 1 foot (there is currently no shower head- it's just a bath). I would like to keep the tub, rip up the tile, install a shower pipe that runs up the wall and across the ceiling to a shower head directly overhead (so the water will be falling straight down in the middle of the bathtub). I was planning then on replacing all drywall with greenboard and different ceramic tile.
The tub currently has about 8" of ceramic tile on all three sides of it (it sits about 8" away from the wall on all three sides). Assuming my plan works, water will be splashing on the new ceramic tile wall and then accumulating in this 8" space (because the lip of the tub is raised above the current -and future- ceramic tile).
What can I do to prevent this? will that standing water hurt anything? Should I just install an oval shower curtain that hangs from the ceiling? Should I build a drain in this 8" space somewhere so that whatever water ends up there will drain out? Should I build the wall out so that the new tile drains onto the lip of the tub? IF so, what happens if I ever have to replace the tub? I'm in way over my head.
Any help would be greatly appreciated.
