Unread 05-01-2008, 07:27 PM   #1
wrx4sabelle
Trowel size for 13" and 6 1/2" tile pattern?
I am laying 13" tile in a pattern with 6 1/2" (or so) tiles, over a slab floor using Versabond thinset. Can I use one trowel size for both? What would be the best size? I have a 1/4" x 1/4", which I think is too small for the 13" tiles but it correct for the 6 1/2". I worried if I use 2 sizes the tiles won't be level.
Carl
wrx4sabelle is offline   Reply With Quote
Unread 05-01-2008, 08:05 PM   #2
Hi Carl, the two size tiles should end up level as long as they are both the same thickness. I would use a 3/8 tall notch and skim coat the backs with the flat side of the trowel.
Unread 05-01-2008, 08:51 PM   #3
wrx4sabelle
Great, thanks, I will get a 3/8" trowel. I was already planning on the skim-coat
Unread 05-01-2008, 08:53 PM   #4
Sometimes I will use a grinder with a 1/4 inch wide grinding wheel to cut notches deeper in my trowels. They tend to wear down after a while. You could do the same instead of buying a new trowel.
Unread 05-01-2008, 09:54 PM   #5
wrx4sabelle
Hey, that's a good idea. I'm trying to find one to borrow but if I can't I may just do that.
