Unread 01-08-2008, 05:08 PM   #1
Tileworks
Tile Contractor -- Akron, OH.
Tileworks's Avatar
Sanity Check
Hey there,
I quoted a square foot price today for a new builder for 2000 square feet of chiseled edge travertine, 16x16. I got quotes for the travertine ranging from $3.95 to $4.75 per foot.
I said "let's figure $12.00 per foot, which included stone tile, backerboard, thinset, grout, and seal." Remember, 2000 square feet, custom home.
He acted very strange and indicated that I was way over priced.
So where do you guys come in? Historically, the whole community here will chime in with how cheap I am and that I should raise my prices.
- Bob
- Bob
Classic Tileworks
http://www.classictileworks.com
Ohio Tile and Stone Installation Contractor in the Akron area serving Summit, Portage, Medina, Stark, & Cuyahoga counties in Northeast Ohio
Tileworks is offline   Reply With Quote
Unread 01-08-2008, 05:18 PM   #2
HS345
Tile Contractor
HS345's Avatar
I'd probably come in around $15.00 to $17.00, depending on the price of the stone. More for Ditra. Of course, I hate giving ballparks, sight unseen.
Sounds like you get a good price for purchasing that type of stone.
Builders just don't want to pay for quality it seems, they just want to GIT-R-DONE!
The name's Greg
Unread 01-08-2008, 06:09 PM   #3
Davestone
Florida Tile & Stone Man
I would have been pretty close to you Bob, slightly higher, but i've been getting outbid by a mile since this RECESSION started. How about my last asskickin....$1.90 labor for chisel edge ashlar pattern over Proflex...stone walls included!
http://Davestonestile.com
Unread 01-08-2008, 06:10 PM   #4
Bob, I don't want to say you're too cheap.
Listen, say you get the stone for five bucks, backer board for .75, tape and screws or nails .25, thin set and grout .25, sealer .25. The add sales tax if you don't have a resale number. With incidentals you're right at seven bucks. That leaves you five bucks to do the work. It's not high. I would bid seven bucks labor and materials at cost. But I've never screwed with "builders." They're all bums, save a very few high-end guys, and they would think your bid is low.
Unread 01-08-2008, 06:29 PM   #5
scuttlebuttrp
Bob,
I'm in Florida and I would have bid higher. With JB's senario, you were left with $5 to install CBU and set the stone, and seal the stone? Your price wasn't too high. Builders are just getting ridiculous.
Royce
Unread 01-08-2008, 07:24 PM   #6
kevjob
Licensed Remodeling GC
kevjob's Avatar
As a Gc that price is too low for stone quality work etc... I have been getting calls from guys looking for work, one guy quotes 1.50 a foot thinset included! the average around here is 6.00 sq ft for porcelain labor tniset only, stone tiles labor and medium bed I pay around 7-10 on floors
Davy you seeing a greater number of too low bids?
kevin
Highlands Ranch CO, Bathroom Remodeling
kevjob is offline   Reply With Quote
Unread 01-08-2008, 08:03 PM   #7
Jason_Butler
Tile Setter
16" Travertine over a slab would be around $6 per sq ft here - just labor !!!
Builders are insane. I've seen what they charge the end user and it's even worse. The last high end home I saw had a tile charge of $10 per sq ft . This is over a slab. I know the tile that was used- I pay $2.25 per ft. I'm sure a volume builder pays less. That leaves over $7 per sq ft for a 13" tile install. I didn't bid it but the two guys that did it were paid by the hour
Jason
Unread 01-08-2008, 09:06 PM   #8
dont take the ait lowering your bids, they want you to drop your price so they can keep theres the same and make money during this drought. and hopefully if they use the "lowball" hack you will be back to fix it later and able to charge them double !
Unread 01-09-2008, 06:52 AM   #9
Tileworks
Tileworks's Avatar
Thanks guys. I knew I was doing just fine. I have other builders that never even bat an eye at my prices.
- Bob
- Bob
Classic Tileworks
