09-08-2007, 11:58 AM
Cost question between cement board and kerdi
Thinking about using kerdi in lieu of cement board....
Cement board isnt cheap, and it appears to be somewhat a bit more difficult to install, especially in my application, two boards thick IF I use the existing pan.
so, IF I use the existing pan,
can I just use normal sheetrock, and put kerdi over it, or will the lower edge of the sheet rock that sits on the shower pan flange, even covered with tile and caulked off at the bottom against the pan, still represent a place of future failure?
Then the next question is, if I decide to rip out the shower pan, do a mud bottom, allowing me to do a great tile floor instead of just the white pan, mean that I could use kerdi, the shower flange and make my own curb?
So the kerdi drains are like $90, and the kerdi approx 60 sq-ft, about $120, would that be all?
I cant help all the questions, after all, I am an engineer!
09-08-2007, 12:17 PM
Larry,
Kerdi is a system. You will have to replace the pan but you can make your own bed.
Have you read JB's "The Kerdi Shower Book"? It is an e-book and the best $10 tool you will ever buy.
09-08-2007, 09:38 PM
Senior Contributor
If you are going to go to the trouble of installing new tiled walls, I'd do the pan as well. While you have things torn up, look at the p-trap as well. If it is pvc, it's probably okay. If it's CI, you'd need to transition to pvc anyways, and CI could be fine, or a disaster waiting to happen. Building a deckmud pan isn't as hard as some think. If you use Kerdi to waterproof it, you only need one layer rather than two, so it is less work, and deckmud is cheap. Working with drywall is much cheaper and easier than cbu, too.
09-09-2007, 06:32 AM
When I read your question It sounds like you are not talking about a traditional shower pan, but a fiberglass receptor. If that is the case then yes, you can use the Kerdi over sheetrock and the pan. End the sheet rock at the top of the fiberglass receptor and run the Kerdi past the end of the sheetrock into the receptor.
Rich
09-09-2007, 06:45 AM
Official Felker Fanatic
Why could you not shim your studs and use 1 layer??
Kerdi Costs more........At least double the cost of CBU and its main benefits are not realized with a fiberglass pan.
Remember, you still have the cost of Sheetrock and since you cant overlap at the base you have an End point where the Sheetrock needs to be sealed or moisture will get to it and wick up and ruin the installation.
If moisture Does get to the Durock (or other CBU) it will not damage the board.......the advantages of Kerdi are that you completely encapsulate everything in conjunction with a Kerdi Pan assembly.......since you will not be doing this a standard CBU installation should serve you well...........Of course everyone knows I am NOT a huge Fan of Kerdi for anything other than its applications as Used with Ditra.
Thats My story and I'm stickin to it
