Unread 02-20-2006, 04:16 PM   #1
INtilesetter
Tile Contractor-- Lafayette Area
INtilesetter's Avatar
TEC 1 Flex
Has anyone ever used this product on floors and is the cure time between tile instalation and grouting any longer than 24 hour wait?
Corby, what friends I have call me!
http://www.simplefamilysupper.com
INtilesetter is offline   Reply With Quote
Unread 02-20-2006, 04:40 PM   #2
Scottish Tile and Stone
Ive used TEC products before, but never had to wait longer than 24 hours.
Scott.
www.scottishtileandstone.com
Laticrete hydroban showers
Mud set stone.
Unread 02-20-2006, 06:30 PM   #3
INtilesetter
Tec 1 Flex is new to me, it is a crack isolation membrane/thinsette in one application. I have used other TEC products , but not this one.
Unread 02-20-2006, 07:49 PM   #4
the tiler
Send a message via AIM to the tiler
I have used it
It is Nasty stuff
Wait till you try and get it off your hands and tools
It dries pretty quick
What kind of tile are you going to use it on ?
Why are you going to use One Flex ?
The white turns light grayish when it dries the Gray turns almost black
Jason
the tiler is offline   Reply With Quote
Unread 02-20-2006, 07:51 PM   #5
Is it something like C cures isolation thinset? If so, damn that stuff is sticky.
Scott.
Mud set stone.
Unread 02-20-2006, 09:21 PM   #6
INtilesetter
using it on a basement slab with small hairline cracks.Laying porcalain mod-hopscotch.They tell me to measure the exact amount of water,thats all I know,, the cost is relative to ditra, but only in one step.
Unread 02-20-2006, 09:28 PM   #7
muskymike
muskymike's Avatar
Hi Corby, I have used it, it is VERY sticky. You will get a good work out too spreading it. Be sure to clean your tools off at the end of the day and throw the bucket away. Trust me, I never throw buckets away but you will want to if you try to clean it out. It is good stuff though.
Musky Mike
Corrado Custom Tile
Kerdi Shower Specialist
New here? Check this out.
Unread 02-20-2006, 11:25 PM   #8
Bellsfloors
Tile, Wood, LVT, Home Renovation Contractor
Bellsfloors's Avatar
I've used it several times and the guys are right about the sticky part. Make sure to have a pail of water and cleaning sponge as you really need to clean out your grout joints as you install. The stuff is plyable once it is set up and little harder to clean out the joints once dry. I keep some on hand for questionable cracks and some hard to bond to surfaces.
Tracy
Flooring-Tile-Waterproof Showers
www.AttentionToPerfection.com
Bellsfloors is offline   Reply With Quote
Unread 02-21-2006, 05:33 AM   #9
INtilesetter
Thank you
Thanks for all your information guys, makes me feel a little more confident on using new product to me, with others experiance. Charge extra for new buckets and trowels huh? just kidden!
Unread 02-21-2006, 08:05 AM   #10
muskymike
muskymike's Avatar
Don't fergit about new pants too! If you git any on yourself.
Musky Mike
Corrado Custom Tile
Unread 02-22-2006, 11:23 PM   #11
Trask
Oregon Tile Man
Trask's Avatar
Sticky is an understated.. it's nuclear waste&velcro. It also does not build up and if you do build it up it keeps sagging back almost like a very slow slc.
I love Tec products but It's got too many potential problems for me to use again have fun
Trask Bergerson
Bergerson Tile and Stone
Astoria, Oregon
Unread 02-22-2006, 11:28 PM   #12
Kx250
Kx250's Avatar
Why not use customs megaflex? but I have not used the tec stuff so I dont' know if It meets your needs.
High Country Tile
Jesse
Somewhere in the middle of nowhere Wyo, next to a Volcano .
Kx250 is offline   Reply With Quote
Unread 02-22-2006, 11:33 PM   #13
Levi the Tile Guy
Tile and Stone Contractor
Levi the Tile Guy's Avatar
I've never used the tec flex, but if it's anything like megaflex Have Fun. I had to use that stuff to set 3/4" marble mosaics in a fiberglass jacuzzi tub. Megaflex is the only product anybody would back, and the customs guy told me they would gaurentee it if I used epoxy grout. Cutting out the mud from 10,000 little tiny grout joints the next day was no fun at all, but the jacuzzi is still in tact and that thing had an enourmous amount of flex to it. In fact I made the homeowner and the GC sign off on my liability (which I know is iffy) before I started, and had a customs rep sign off saying megaflex would work. 2 years later and not one single piece has popped.
Levi The Tile Guy
Unread 02-23-2006, 06:34 PM   #14
INtilesetter
Trask,....potential problems?
