For a normal thinset, yes, 1/2" would be too thick (typical thinset max is 1/4", with 3/16" nominal). BUT, if you read the spec sheet for DitraSet, it is also listed as a medium bed mortar, and yes, it will work at the depths you anticipate needing. If the walls were really flat (other than the corners), AND the tile are quite flat, you might get away with a smaller notch. Industry guidelines are based on a typical tile, and yours may or may not be. The Ditraset lists a range of water to use, and at the thicker application, you'd probably want to be using nearer the low end of the range of water. But, you still need it to be embedded into the fleece on the Kerdi.
IOW, you should be okay continuing with what you have.
