Unread 03-11-2014, 03:00 PM   #1
Roy Sams
Vapor Barrier or not Vapor Barrier behind Backer Board
I just watched a YouTube video. The video I think was well done by an experience person. However he stated that placing a vapor barrier behind a shower with a backer board installation was a no no. The location of his installation was in GA. He stated that the vapor barrier would lead to mold between the barrier and backer board. He also was using a board that already had a vapor barrier incorporated into the board. He stated the vapor barrier was old school from the 80's and 90's
I on the other hand already purchased the USG 1/2" thick backer board. I am also installing the shower in the basement in WI. The shower stall walls are not against the basement's exterior walls.
Suggestions
Roy
Roy Sams is offline   Reply With Quote
Unread 03-11-2014, 03:13 PM   #2
Richard Tunison
Retired Tile Contractor
Hi Roy and welcome.
Have you decided to build a traditional shower with a rubber liner and poly behind the backer boards that drapes into the inside of the pan?
Let us know and we will advise.
Richard
Richard Tunison is offline   Reply With Quote
Unread 03-11-2014, 03:41 PM   #3
Roy Sams
Yes this will be a tradition shower stall installation; thick mortar bed install with the PVC linear. The shower wall will be Durlock USG backer board. Instead of poly I was thinking of using Tar Paper. Which brings me to my question: Should the backerboard have a vapor barrier behind it?
Roy
Unread 03-11-2014, 03:46 PM   #4
Richard Tunison
Yes, a MOISTURE barrier is used behind the wall board and tar paper is fine. In lieu of that a surface applied membrane can be used but never both as it creates a "moisture sandwich".
A few diagrams for you to get well acquainted with.
Richard
vapor barrier hardie backer LBT Tile Forum/Advice Board 7 02-15-2014 02:27 PM
203K construction debacle - to vapor barrier or not to vapor barrier ncraig Tile Forum/Advice Board 16 06-29-2013 10:41 AM
vapor barrier for hardie board mojosand Tile Forum/Advice Board 7 04-29-2011 11:15 AM
backer board on top of green board/no vapor barrier mujerista Tile Forum/Advice Board 3 01-29-2009 03:43 PM
Vapor barrier behind cement board? Netty Tile Forum/Advice Board 5 05-25-2005 06:38 AM
