Unread 05-11-2018, 09:51 PM   #1
big2bird
Six years later/Bathroom #2
I would like to thank all in advance for any contributions.Everyone here was very helpful with my last bathroom 6 years ago.
Thankfully still planning, I have a few questions. The tile "She who must be obeyed" selected is 5/16"x6"x36 porcelain. I have read and understand the 30% rule when laying this non-rectified long tile.
The floor I have to match in height is 3/4" plank with 5/8 T&G plywood with 5/8" engineered hardwood over that. SO, I have 1 1/4" to play with over the 3/4" planks in the stripped bathroom. The SLA will be 720 after floor reinforcement.
The wife also desires heated floors.
My thoughts are 1/4" cement board screwed down on 6" centers, tape and mud seams, then red guard and primer. Install the heating wire, then pour SLC up to "X" height, then modified mortar and the 5/16" tile.
Oh gurus of the tile world, please tell this old retired electrician what YOU would do. I used slc in my last project, and like the idea of embedding the wire to protect it, and enable a re-tile later if needed.
Jeff, Retired electrician
big2bird is offline   Reply With Quote
Unread 05-12-2018, 01:45 AM   #2
Hi Jeff, welcome back. I never plan an install so the tearout will be easier and embedding the wires in SLC doesn't guarantee an easy tearout for later. Myself, I would look into using Ditra Heat and avoid the SLC.
Unread 05-12-2018, 06:17 PM   #3
big2bird
Okay, the engineer swung by today. To attain the lowest deflection, we are adding a beam to lower the 2x6" 16" oC joists to 5' span. He wants all the plank flooring removed, and 2 layers of T&G 58" plywood installed.
So I ask, is heating cable (Warm wire), okay directly on plywood? I would then pour slc up to match existing finish. Do I need plastic mesh in that stuff?
Unread 05-12-2018, 06:33 PM   #4
One of the things to consider...when you're dealing with a heated floor, the amount and rate of thermal expansion is much greater than in a 'normal' tiled floor. I'd really consider something like DitraHeat to aid with that condition.
While you can use 5/8", to get something that will hold a screw for the second sheet better, condsider using 3/4" for the first layer and 1/2" for the second...the screws will bite better with less chance of tear out.
Unread 05-12-2018, 06:42 PM   #5
big2bird
Is ditra heat a system I can use my purchased heating cable in?
I understand about the screw jacking tip.
Unread 05-12-2018, 06:50 PM   #6
Ditra Heat is a system, although you can buy parts of it individually. I don't know if Warm Wire can be used over their mat, but you can check with their tech support.
There's also a thread in the pro hangout about Ditra Heat, and I think some installers showed where they had use other brands of wire with the Ditra Heat mat.
Unread 05-12-2018, 06:52 PM   #7
big2bird
I'll check that out. Now I looked at the specs, and the one I looked at was for over concrete or concrete board only. Is there more than one type?
Unread 05-12-2018, 08:48 PM   #8
DitraHeat certainly can be installed over a wooden subfloor (ply or osb). https://resources.schluter.com/media...ationGuide.pdf
Whether the heating wire you have will snap in well, not sure...You'd need to check the OD of the wire.
Unread 05-13-2018, 07:00 AM   #9
big2bird
Okay. 3/4" plywood over joists. 1/2" plywood over that. Ditra heat over that, then lay the tile to FF. Got it. Thank you very much.
Unread 05-13-2018, 08:37 AM   #10
andre.g1
Don’t bother priming after red guard. Look into Ditra Heat as an option.
Andre
Valleyview, AB., Canada
Andre
andre.g1 is offline   Reply With Quote
Unread 05-14-2018, 06:56 AM   #11
big2bird
Smile
I found a cut sheet from Warm Wire showing their cable in Ditra Heat membrane. So, I'm good to go.
Unread 05-17-2018, 10:26 PM   #12
big2bird
Question. I need to lay detra heat-TB , 5/16" tile and thin set to attain 3/4" ff.
Is that reasonable? I am not sure what the compressed height of thin set is. I believe Detra heat is 1/4" and TB is 5/16".
Unread 05-19-2018, 08:33 AM   #13
big2bird
Talking
I guess a test board will tell.
Unread 05-19-2018, 10:47 AM   #14
Always the best approach if you think the measurement will be critical, Jeff.
Unread 07-31-2018, 10:41 PM   #15
big2bird
Ditra Heat
Getting ready to install Ditra Heat and Warm Wire in a bathroom.
Are their any pros and cons about embedding the cable with unmodified thin set mortar
the day before laying tile? Thinking filling it to the top of the cones and floating off to give a normal level surface and protect the cable.
10 years in the making bathroom remodel Gozo Tile Forum/Advice Board 154 01-28-2021 07:34 PM
D-Day 70 years ago Peerless Tile The Mud Box 6 06-06-2014 05:54 PM
What are you Doing New Years Eve? kate42 The Mud Box 41 01-01-2008 05:52 PM
40 Years Derek & Jacqui The Mud Box 7 03-29-2004 08:41 AM
911 Two Years later... fishinfarmgirl The Mud Box 16 09-12-2003 10:01 PM
