05-24-2006, 03:27 PM
Tile Contractor
slip joints
does anyone actually put slip joints in their showers?
Jared
You can lead a horse to water but you cant get that bird out of my bush!
05-24-2006, 04:57 PM
Jered, tell me what a slip joint is, and I might incorporate one here and there.
No.
05-24-2006, 06:16 PM
Remodeler -- Southern Cal.
I tried to once, but slipped.
I think he must mean control joints or expansion joints. If that is what you are meaning--the answer is no.
Scooter
WC Fields, "Its a Gift" 1934
05-25-2006, 07:10 AM
General (Tile) Contractor
What if it was a huge gym shower or something? The showers in a pool I worked at when I was a teenager was probably 16 x 20 or something, and had a ton of showers and drains in it. I have no idea if they had any control joints in it or not, but with something that size I would think it should have.
=Eric=
General contractor with a tile habit.
05-25-2006, 07:20 AM
Tile Contractor
Well since everyone here relies so much on the tca handbook which is a good reference that only goes so far then you should know what a slip joint is!
Jared
05-25-2006, 08:03 AM
wd've been nice to tell a bit more. Anything more. Did you read it recently in the TCNA book? R U sure?
i web searched 'slip joint' and found it applies to linear expansion, and is used in plumbing but not tiling. According to the first hundred of ten million hits.
David.
"Do a search, find out what you can, and come back with more questions."
"...slower than the average DIYer
05-25-2006, 08:07 AM
Tile Contractor
it has been in the handbook for quite a while. it is shown under steamers at this point in time.
Jared
05-25-2006, 08:10 AM
Are you talking about a movement joint???
Bryan
05-25-2006, 08:19 AM
ok, maybe it makes sense on the steam supply pipe.
like a ring with rubber inside to let the pipe inside it lengthen and shorten a bit (that would be slip, in my opinion). Makes sense for a steam thing where temperature goes up and down by a hundred or more degrees.
David.
05-25-2006, 08:21 AM
Tile Contractor -- Napa, CA.
Hi Jared,
I see it too. It's to isolate the lid from the walls. Looks like they have foam backer rod and caulking there.
I was also taught that ceiling lath (on a floated one) isn't supposed to wrap down the wall, for the same reason. I didn't notice that in the TCA.
Mark
05-25-2006, 09:44 AM
lathe
The only wrap I perform in a shower is the curb. And somtime the wife, if you know what I mean......... But correct on the shower ceiling, always did it but didn't really stop to think about it. Makes sense though because of the rising of the steam and moisture. HHHHMMMMMMM..............
05-27-2006, 10:25 AM
I wrap the vertical corners with lath in my showers. I think the 'wife wrap' would make homeowners feel awkward, and that 'war' can be pokey.
Mark
05-27-2006, 11:19 AM
Oregon Tile Man
Steam showers are an entirely different animal than a standard shower...though I have in the past floated larger showers that isolated each wall as a seperate panel, divided by closed cell foamstrips and the wire was not wrapped in the corners, the open joint then filled with sealant.
I think I got into this from my trip to CTEF..pretty sure we isolated all walls when floating there.
05-28-2006, 08:54 AM
Forgot we were talking about steam showers, I got distracted by the 'wife wrap'
Trask,on a regular shower, how large of a wall are we talking about, to start thinking about isolating walls from one another? Gang shower'ish sized?
Mark
05-28-2006, 12:35 PM
#15
Oregon Tile Man
Really I think you should on any to be by the book, but that's just my gut instinct and honestly it rarely happens. The last shower I did this on was about 8'x5' in a residence. I also added wire and "moose milk" (just a little latex) to the dry pack cause it was so large and a little on the thin side,(1 1/4"). I think all this is a bit of extra work and that's why it's not always done, but I don't think it hurts if your in the mood for something to last forever and a day. This happened to be in very high brow clients house who wanted to watch and was not shy about paying for details.
