Old 06-21-2018, 01:44 AM   #16
rnln
that's good news. Laticrete Stratamat is more affordable. I am settled. Unless, if anyone else know any other alternative. It's long way for me to get to actual laying the floor anyway
Thanks everyone again.
Ronald
rnln is offline   Reply With Quote
Old 06-21-2018, 06:54 PM   #17
mark999
Sounds like you are getting ready to get ready
Mark
mark999 is offline   Reply With Quote
Old 06-21-2018, 08:56 PM   #18
BobbyNorthSouth
Mapelastic CI is about $102/3.5 gal bucket at Floor & Decor
Ronald, I've used about half a 3.5 gal bucket to go over a 150 sq ft master closet in preparation for tiling...so if a $110 out-the-door bucket covers 300 sq ft, that's around $.36/sq ft.
That's almost 1/3 the cost of the Laticrete Stratamat, and also meets ANSI A118.12.
You roll the Mapelastic CI on with a 3/8" nap roller. http://www.mapei.com/public/COM/prod...cci_tds_ea.pdf
The two products are probably an apples and oranges comparison, but I've got the same problem you do.
When I demo'ed my tile, I found more cracks in the slab underneath (but there were none in the tiles or the grout lines), and they used some maroon/brown paint-on crack inhibitor that obviously worked (don't know if it was Mapelastic CI).
If you're sold on the Stratamat, one of the site sponsors (stonetooling.com) sells it for $299 for 323 sq ft ($.93/sq ft), cheaper than the rainforest-named mega e-retailer.
Bobby
BobbyNorthSouth is offline   Reply With Quote
Old 06-25-2018, 11:41 AM   #19
rnln
Mark999,
Yeah, I like to lay things out, include cost, before I start. And when I started, I like to stay on it unless somethings go wrong
Thanks Mark.
Hi BobbyNorthSouth,
Thanks for your info. Let me make sure. Laticrete Stratamat is the mat/sheet. I need to get glue to glue it to the concrete. But mapelastic is the liquid form membrane. I need to to roll it on the concrete, no glue, no mat/sheet.
If this is correct, can I ask if this Mapelastic bind to the concrete similar to paint, or it glues tight into the concrete, or it just lay on the concrete and you can be able to pull/peel it up?
Thanks Bobby.
Ronald
Old 06-25-2018, 06:21 PM   #20
mark999
What kind of transitions are you dealing with? Sometimes that makes a difference of what type of membrane(thickness) You want to use.
Mark
Cracked Concrete alfredo Tile Forum/Advice Board 26 06-24-2005 06:33 PM
Tile over cracked concrete Greenman Tile Forum/Advice Board 3 01-20-2005 08:58 AM
mud base over cracked concrete J.Roddick Tile Forum/Advice Board 23 12-23-2004 06:53 PM
Tiling over cracked concrete Unregistered Tile Forum/Advice Board 5 10-26-2004 07:58 AM
ditra over cracked concrete dave on his knees Professionals' Hangout 4 05-09-2004 09:45 AM
