Old 02-08-2004, 02:57 PM   #1
cal
Shower Remodel
Greetings everyone!
It has been awhile since my last post. I have recently completed my first mud curb. How do you determine the height of the drain? I understand how to determine the amount of slope for my shower. I have read several threads about tiling the walls first vs. starting with the floor. Would someone explain the benefits / drawbacks? I am leaning towards starting with the walls. The pics from JB's mud curb article show him installing the wall tiles and curb tiles before packing in the deck mud.
Great article JB! My brick mortar was not quite as stiff as it should have been. I had a little sagging. Not much though. The important parts are that both sides are parallel, level and straight.
I will try to send some pictures.
CAL
cal is offline   Reply With Quote
Old 02-08-2004, 04:55 PM   #2
Hi Cal,
The height of the drain should be a minimum of 1- 1/4 inches from the surface of the pan. More is better, of course. The drain will screw up to about 2 in. max. Anywhere above the 1- 1/4 in. height.
Old 02-08-2004, 06:13 PM   #3
John left me a crumb.
Cal, some of us like tiling the floor last to keep from having to protect it. If you tile the floor first it'll need to be covered to keep from doing any damage to it while working on the walls.
Old 02-09-2004, 06:24 AM   #4
tileguytodd
Official Felker Fanatic
tileguytodd's Avatar
Hi Cal, the guys didnt even leave me a crumb.Sorry i was a bit late getting here, i couldnt get in last night.not sure if it was our server down or my ISP.Anyways,you have what you need.i'll keep an eye on your progress.Best of luck to you!!
