Unread 09-16-2022, 11:35 AM   #1
atvkid4eva
Which Thinset wall/floor
I am doing my first tile job in a bathroom remodel. The alcove tub surround will be 4x12 subway tiles and I will be using Kerdi Board as a backer. The floor tile will be 12x24" Porcelain tile. I want a high quality Thin-set for both applications. I've read good stuff about Ardex thin set and various others, Is there one thin set that has no sag for the wall and can still be used on the floor?
Please recommend me either one thin set for both applications or one for each.
Bobby
atvkid4eva is offline   Reply With Quote
Unread 09-16-2022, 04:32 PM   #2
Bobby, I wouldn't worry about the "non sag" claim. Some thinsets are pretty good at holding tiles in place but I would still plan to use wedges or spacers on the walls. Throw that out and you have a lot of thinsets to choose from. Versabond LFT is a good one and so is Prolite. Home Depot has both along with a few others.
Unread 09-20-2022, 09:30 PM   #3
Snets
Professional Weekend Warrior
Snets's Avatar
4X12's are pretty light, I'd not worry about sag, assuming you will be using some spacers. if you mix thinset mortar to the instructions, it will hold a small tile like that very well on a wall, especially when you achieve full mortar coverage - which you should - and that is only achieved by walking that tile back and forth, compressing the ridges of the trowel notches fully.
Unread 09-24-2022, 09:59 AM   #4
Tiger Mountain Tile Inc
If you are using Kerdi and you can get your hands on Schluter All-Set then that would be a good choice.
James Upton
Mapei Thinset Advice Sought - Restrooms Floor and Wall ranchopedro Tile Forum/Advice Board 10 12-30-2020 12:44 PM
Wall/floor & wall/wall connections for foam panels westydog Tile Forum/Advice Board 3 08-04-2020 04:09 PM
premixed thinset vs. actual thinset mortar on floor Steve in Liberty Tile Forum/Advice Board 7 11-03-2009 11:40 AM
Thinset, grout, or Silicon at floor/wall transition? Mike D Tile Forum/Advice Board 1 02-19-2009 07:21 AM
Concrete floor, plaster wall, concrete backboard: Thinset(s)? Laine MacTague Tile Forum/Advice Board 5 04-13-2006 09:13 PM
