Unread 09-06-2022, 09:14 PM   #1
jnthnlsn
Porcelain slab countertops
Hi all, I am installing an office and we decided to go with Porcelain countertops. I realize this is not necessarily the place for countertops, but hoping for some thoughts as there is not much in the installation instructions out there. I thought it might be similar to a large format porcelain tile install. We are having them fabricated to size (24” by 92”) and planned on installing myself them over ¾ plywood on top of cabinets. I have thought to install uncoupling membrane and use a large format mortar, but have seen/ heard of others using epoxy or other adhesives that do not require the other prep. They sometimes install them over existing granite in remodels. They won’t carry much weight as a desk top compared to a floor application. Any thoughts are appreciated.
Jonathan
jnthnlsn is offline   Reply With Quote
Unread 09-07-2022, 06:22 AM   #2
Hi Jonathan,
Sounds like a plan. Just make sure you have full coverage with the mortar, and press the panel down all over.
Unread 09-08-2022, 05:19 AM   #3
Tile Money
Porcelain Countertops
Hi,
Bostik makes an adhesive called Bosti-Set,
This adhesive is like glue and can be installed directly to a lot of things that thin-set has limitations.
What is your plan for the trim around your countertop tops?
Miters?
What thickness is your porcelain?
Luke
Tile Money is offline   Reply With Quote
Unread 09-08-2022, 10:58 AM   #4
Nicpaus
Make sure the nose covers the plywood. We use 5/8 not 3/4. Post some pictures after installation.
Nick
Nicpaus is offline   Reply With Quote
Unread 09-10-2022, 09:02 PM   #5
jnthnlsn
Thanks all, much appreciated. We are having them add a 2” miter on the edge so the exposure shouldn’t be an issue. It ½ inch (12mm) slab.
Jonathan
Unread 09-11-2022, 03:42 AM   #6
CaliGrown
CaliGrown's Avatar
Nice choice with the Porcelain Slabs and a mitered edge at that!!! Lotsa options and possibilities
Ardex WA is what we used at a training event for GPTP, full spread and 100% contact/transfer is crucial
Please keep us posted with the progress and finish!
“ Most times ya set tile, other times tile sets you!”
Christopher Machado
https://www.machadotileco.com/
granite slab countertops, deflecto calc needed? mad1ben2 Tile Forum/Advice Board 2 09-18-2006 08:51 AM
Need Advise - Granite Slab Countertops healthyguy Tile Forum/Advice Board 21 08-24-2006 05:00 PM
slab granite countertops bml Tile Forum/Advice Board 13 05-10-2005 06:38 PM
Slab Granite Kitchen Countertops DreamQueen Tile Forum/Advice Board 8 01-12-2005 06:16 PM
Installing granite slab countertops andiebc Tile Forum/Advice Board 24 02-15-2004 07:19 PM
