Unread 07-31-2016, 02:35 PM   #1
Dawenk
Reapply Sealer - Solvent based
Hi,
I have about 10,000sq travertine pavers on a patio. I applied StoneTech Enhancer Pro sealer a year ago. Looks great but I still find that it will stain if I do not get the leaves / flower peddles off the tile before they get wet. If it sits a few days I do get a stain.
Can I just reapply a new coat of the StoneTech (solver based) right over the year old coat or do I need to strip it.
Doug
Doug
Dawenk is offline   Reply With Quote
Unread 07-31-2016, 06:39 PM   #2
Hi Doug, welcome. That's a penetrating sealer so there shouldn't really be any build up to strip off. I would make sure the travertine is clean and dry and seal it again. Right after you apply the sealer, you will probably will have to wipe off the excess. Do a small area at a time. Read the label and follow the instructions, you'll do fine.
I'd pick the coolest time of day to seal it and avoid the overhead sun.
Solvent Based Sealer in Canada Carolina1 Cleaning, Restoration and Sealing 2 08-16-2015 08:46 AM
water based vs solvent based sealer woodvette Cleaning, Restoration and Sealing 3 05-07-2013 06:24 PM
Effects of solvent based grout sealer on water-based silicone caulk jagger295 Tile Forum/Advice Board 6 03-18-2007 01:27 PM
Solvent based or H2O based sealer/enhancer? Rouvin Cleaning, Restoration and Sealing 6 02-21-2007 08:37 AM
Solvent/oil over water-based sealer on Saltillo eadmar Cleaning, Restoration and Sealing 3 06-12-2006 05:31 PM
