Unread 03-13-2016, 11:21 PM   #1
toolwarrior
Any word on the new Hydro-blok system?
Our local tile contractor supply warehouse not only carries Schluter and Wedi, but they are now carrying the Hydro-Blok system. I have used the Schluter system before and wanted to try the Wedi system for a new tile job coming up, but fell out of my chair when I reviewed the pricing for the various components. My supplier then told me about Hydro-Blok. The pricing is significantly better than Wedi and looks to be the same in every way, except color. I did some research and I can't seem to find anyone reviewing or commenting on the new Hydro-Blok system. Has anyone tried it yet or heard anything about it vs the Wedi system?
Rich
toolwarrior is offline   Reply With Quote
Unread 03-14-2016, 01:23 AM   #2
rocjr
GC
rocjr's Avatar
Rich
It *looks* to be identical down to the drain. Check with them regarding any limitations regarding minimum tile size on the pan. Note, the subfloor really needs to be deadly level with any foam pan. I needed to pull it and tweak to get there. The pitch was not aggressive with Wedi. I was sure the drain was dead on center between curb and wall and wall and wall. The upside was that it was fantastic to install. I did add cleat sticks at the seams between stud bays, but I do that even with cbu to pull them into plane. I set the pan and let it dry over night. Doesn't sit well with me dancing all over it while wet. I also didn't lock in the drain donut til the next day. There's a tendency to get some lift when tightening them. I learned that early on in the acrylic pan days.
Rich
rocjr is offline   Reply With Quote
Unread 03-19-2016, 10:52 AM   #3
toolwarrior
Thanks for the feedback. Seems to be so new that few, if any, have given it a try. I have researched this product a bit further and found that the install method is slightly different for Hydro-blok. In the corners, they want you to nest in some fiberglass mesh tape and coat with the sealant a second time. That has pros and cons. While it is another layer of protection, it also consumes more of the sealant and also takes more time. I am going to present all the information to my customer and let them make the choice. Wedi is a known entity. However, the cost difference just can't be ignored on this Hydro-blok system.
Rich
Unread 03-19-2016, 06:04 PM   #4
Tiger Mountain Tile Inc
I heard there were some problems with it. But what I heard was more rumor than anything- nothing real specific. I'm staying away for now. I still like Wedi.
James Upton
Unread 09-12-2016, 03:52 PM   #5
Higgins
Higgins's Avatar
hydroblok
i was looking for some wedi at united tile everett. no longer carries it, dal tile no longer carries it either, but the daltile everett sez there waiting on there new shipment of hydroblok. what's with this stuff. i don't see anywhere on the forum a discussion of actual use..
mike
Higgins is offline   Reply With Quote
Unread 09-12-2016, 06:04 PM   #6
rmckee84
rmckee84's Avatar
Laticrete? Who makes it?
Ryan McKee
Unread 09-12-2016, 09:11 PM   #7
Hi Mike, Master Wholesale picked up Wedi after Dal dumped it in favor of Hydro block. The old Wedi rep is the guy that started that company. I'm not sure who carries Wedi on the north end.
James Upton
Unread 09-12-2016, 09:39 PM   #8
sycamorebob
HYDRO-BLOK can be found here: http://www.hydroblok.com/
They offer a lot of options.
Patrick
sycamorebob is offline   Reply With Quote
Unread 09-12-2016, 09:43 PM   #9
Higgins
Higgins's Avatar
going into seattle is too much trouble these days...i just want to know if there are any ex wedites that have used hydroblok and are willing to share their experience?
mike
Unread 09-12-2016, 09:52 PM   #10
Topspin
SchluterUgrad
Topspin's Avatar
Tried HydroBlok one time last month on a tub surround. Performed exactly like Wedi. No drain or pan of course. Used one of their 12x12 niches. Funtional but the concrete exterior surfaces on the boards I got were almost glass smooth. Not sure if that affects bonding but definitely smoother than Wedi boards. Niche was kind of a mess appearance-wise but performed fine.
Update: just talked to the distributor who said my early-adopter boards was from a batch made differently than avail now. QC tweaking. Reason niche was different looking than Wedi was due to thicker layer of cementitious top coat for added rigidity. Smooth finish, but definitely ridged.
Was a $1 or 2 less than Wedi per board. Thought I'd give it a try. S'Okay
Unread 09-12-2016, 10:00 PM   #11
Higgins
Higgins's Avatar
thanks for the reply. i thought is was going to a lot more savings than $1- 2 cheaper per board.
mike
Unread 09-12-2016, 11:50 PM   #12
ded dux
ded dux's Avatar
It is to those who supply it, but why sell it that much cheaper when people were paying for Wedi, and this is "just like Wedi".. i'll pay the 1-2 extra. What's their warranty or product support like...maybe "just like" something is good enough.
Don
ded dux is offline   Reply With Quote
Unread 09-13-2016, 10:07 PM   #13
I'm with you guys. I ain't switching.
James Upton
Unread 09-14-2016, 10:28 AM   #14
Looks to me like the only dealers are in Washington and Oregon.
Where are the field trials? How many of these showers have been built? How long do they last? Lots of questions.
Unread 09-14-2016, 01:21 PM   #15
Higgins
Higgins's Avatar
well there's no more wedi north of seattle. dal tile/everett switched to hydroblok and united tile has also dropped wedi. united said it was because of the cost of accessories, in particular pan extensions, and linear drain systems. also the everett united tile location is consolidating with renton and they're both moving into seattle's tile district. bummer for me. they also said it was faster and cheaper to get a container from china than Germany. fyi the hydroblok 3x5 1/2" was $41 and the 4x5x1/2" was $61. i think wedi is quickly become history in the u.s.
mike
Hydro Ban vs Schluter shower system LegacyFloors Professionals' Hangout 9 03-18-2015 05:59 PM
Hydro Barrier and Hydro Ban ande Tile Forum/Advice Board 5 05-18-2014 06:04 PM
Hydro Ban and Hydro Barrier in conjunction? Sanjuro82 Professionals' Hangout 23 05-31-2013 10:24 AM
A Word of Caution... MNTileGuy Professionals' Hangout 15 08-23-2010 04:55 PM
3 Word Story Oldrem The Mud Box 1018 07-21-2006 07:53 AM
