Unread 09-20-2020, 08:10 PM   #1
venuni
Tiles on Hot mop
Hi, I got hot mop done for my shower. Can someone please let me know how should the tiling be done on hot mop. I would like to ensure it is done right. Thank you.
PS: I am in San Jose, CA. I have city inspection tomorrow to check for any leaks. Hoping to pass the inspection so tiling can start day after. Thanks in advance.
venuni is offline   Reply With Quote
Unread 09-20-2020, 08:25 PM   #2
Welcome, Venu.
Please add that geographic location to your User Profile so it appears in each post and is not lost before we leave this page.
Are you doing the tiling yourself?
Unread 09-20-2020, 11:43 PM   #3
venuni
No, I have a contractor doing it for me. But so far quality of his work has been questionable. Failed inspections, rework etc. So I would like to understand this so I can verify/question.
Venu
Unread 09-21-2020, 08:27 AM   #4
Well, it would be best if you first knew what he planned to do, but.....
Generally, the walls would be covered in CBUs or fat mud (in your area there are probably still mud men available, I think) with either a moisture barrier membrane behind the wallboard or a direct bonded waterproofing membrane on the interior face, then a "mud bed" consisting of sand and Portland cement and not much water would be installed over the hot-mopped floor at a thickness of at least 1 1/2" to follow the slope of the tared floor, which must be a minimum of 1/4" per horizontal foot.
'Bout all I can tell you on a generalized question such as you've asked.
Find out what he plans and we can tell you if it's satisfactory. Only thing you can do in the interim is to measure the slope of the hot-mopped receptor to determine if that part was done correctly.
Unread 09-21-2020, 02:43 PM   #5
You could pour some water into the pan and see if it leaves any puddles as well.
In a shower, the waterproofing is the liner (in your case, hot mop). Neither the tile nor grout are considered the waterproofing, and code calls for the pan to be sloped to the drain so that any moisture that gets there has a chance to drain out naturally via gravity. In this type of shower, the mud bed tends to remain damp, with water flushing slowly through it after the first few showers. If it can't flow out, it can accumulate, and that's when things start to fester and smell often leaving the grout damp and promoting mildew.
Unread 09-21-2020, 08:34 PM   #6
venuni
Thank you. I will check with him and post.
Venu
Unread 09-22-2020, 07:03 PM   #7
I would check the weepholes in the drain to make sure they are clear of tar.
In 45 years, I've probably torn out 10 showers that had a moldy smell. And, none of them had a preslope and most had clogged weepholes. From my experience, when the shower is installed correctly, it's not as big a problem as some would like it to be.
Unread 09-24-2020, 11:07 AM   #8
venuni
I was told mud, mesh wire and then tile is how the finishing will be done. Can you please advise the best way this needs to be done. I have a feeling they don't know too. I overheard them saying they need to check YouTube videos.
Venu
Unread 09-24-2020, 01:40 PM   #9
I'd ask them how much experience they have doing mud work. You shouldn't have to teach them anything. It's not rocket science but there are a lot of important details involved. Even having the correct mud recipe and having it properly mixed is very important to get it to stay on the wall.
Unread 09-24-2020, 04:09 PM   #10
smifwal
yikes
Mosaic border tiles not as thick as field tiles. PICS DannyJ Tile Forum/Advice Board 3 09-06-2009 04:42 AM
Listello Question: How to get different thickness tiles flush with my wall tiles? Panzer 5 Tile Forum/Advice Board 8 02-12-2009 10:06 AM
Mexican Saltillo Tiles – Pool Room – Harden Surface / Tiles smooth_player Tile Forum/Advice Board 3 02-20-2007 01:00 PM
Does vertical tiles or small mosic tiles *affect* room size chefwong Tile Forum/Advice Board 7 07-04-2006 05:53 AM
