01-17-2010, 07:43 PM
CSC
Luke's Bath Remodel
This is how I do a shower pan. I'm sure it breaks some rules, but the inspectors are okay with it. Posting it here to see if you guys approve.
I start by cutting 1" wide strips of 1/2" Hardie and back buttering them, then I put them around the perimeter of the shower and I nail them down.
Then I spread thinset over the entire area, from 1/2" thick on the edges down to regularly troweled thickness in the center.
Then I measure for the drain and transfer the measurements to....
-Luke
Quality Crapsmanship.
In love with liquids.
01-17-2010, 07:47 PM
CSC
A piece of backer!
Then I cut the backer and back butter it and squish it into the thinset. I then nail around the edges and around the drain, and tape my joints.
-Luke
01-17-2010, 07:52 PM
CSC
Then I check it out, I have the 1/4" per foot of required slope(actually a little better).
EDIT: I attempted to switch the order of these two pics, but was unable...
-Luke
Reason: BLAH
01-17-2010, 07:55 PM
CSC
After this I will use a liquid waterproofing membrane, flood test, get it inspected and then put on another layer of hardie, and tile and what-not.
-Luke
01-17-2010, 07:59 PM
My opinion, I don't like it. Cement boards are designed to be anchored down, not just thinsetted. You're a tileman, tilemen mix cement, or should. 5 bucks worth of cement and 20-30 minutes would have done the same thing but better.
You're gonna put another layer of Hardi over the pan?
01-17-2010, 08:24 PM
Member of Million SF Club!!
Oh Boy!
Your log-in explains your methods, Coping Skills
I have seen that done with plywood for a preslope only but never a whole shower.
01-17-2010, 08:35 PM
yeah, and what-not
01-17-2010, 08:37 PM
CSC
Yes, I will put another layer or backer over the membrane so the pan will meet up with the top of the 3-piece drain.
Davy, I am not necessarily a tile man. One of sorts, but I work in all areas of construction/remodeling. The backer is mechanically fastened, but only on the edges and near the center.
Don't like it, eh?
-Luke
01-17-2010, 08:56 PM
Tile Contractor Nashville, TN
I vote to cut this out and discuss under the title of "Hardi Shower Pan".
Brad
01-17-2010, 09:26 PM
We know this is improper. Let's show why for those that may come along with the same situation. Luke came to the right place to learn a few things, we all gotta start somewhere.
Brad
01-17-2010, 09:27 PM
CSC
How do I go about doing that?
-Luke
01-17-2010, 09:31 PM
01-17-2010, 09:40 PM
Ya Luke not a good set up at all. that second layer of hardi is gonna be saturated all of its life and really gonna be a breding ground for mold. IMHO it dont matter what the inspectors think cause Ive never met one who "truely" understood the principles behind a properly built shower.
Couple questions,
*How are you treating the wall to pan connection?
*What is being done at the weeps?
*Why, without any proper knowledge of shower construction are you selling a client a shower built in this manner, Or is this your own home?
Jeremy
Cascade Tileworks,llc
Licensed, Bonded & Insured
WA Lic# CASCATL894QA
01-17-2010, 09:42 PM
CSC
No Rick, how do I go about moving it?
I named it the Hackbacker pan for a reason; I am aware that most would consider me to be a hack.
EDIT: Yes, this is my home. I would not be able to, in good conscience, sell someone something I had not done at least a couple times before. I asked the inspector about it before I decided to do it.
I am putting hardi down to the pan and taping the corners, then painting on a membrane.
EDIT: Leaving the weep holes open.
-Luke
#15
Oh, BTW Luke. Don't go anywhere. This may get ugly, but we all want a successful install for you and your customers. Remember that.
I have asked cx to chop this out. Moderator hasta do it.
Brad
