Unread 01-24-2008, 01:38 PM   #1
jd77
Tile and Stone Setter
jd77's Avatar
You can do it - We can help
Hi everyone
Every now and then I run accross a situation that just has to be shared. Here we go..........................
A good client's friend called me the other day in a panic. She had been having her master bath remodeled and was at her wits end because of the contractor.
It seems that Mr. Contactor was getting most of his advice right out of the Big Orange.
He had been there for several months on and off putting a new heated tile floor, tub deck/apron/splash, new glass block window, shower etc. He got as far as the shower before she finally melted down
She decided to not use the shower until I could get there to look at it.
Here is what I saw.............
JD
"Consider any individual at any period of his life, and you will
always find him preoccupied with fresh plans to increase his comfort."
Alexis de Tocqueville
jd77 is offline   Reply With Quote
Unread 01-24-2008, 02:08 PM   #2
dbol
dbol's Avatar
hard to tell what is wrong with it. Other than knowing they got there info from HD. Small pieces are hard to hide when doing castle block.
doug
dbol is offline   Reply With Quote
Unread 01-24-2008, 02:31 PM   #3
lou432
Tile Man -- Southern New Hampsire
lou432's Avatar
Can`t tell much about it with the pics?? If theres somtin rong I can`t see it.
Is that a square drain? Kerdi? Looks like the layout wern`t too bad ! Will there be a test at the end?
Louis
White sand+ blue water .
Find the grace in things that you can`t change, and help some body if you can!
"Van Zant"
I`d rather be on my Harley thinking about God than in Church thinking about my Harley .
My Tile Work Pictures
lou432 is offline   Reply With Quote
Unread 01-24-2008, 02:43 PM   #4
MudMaker
MudMaker's Avatar
Other than that metal corner stuff which I don't like inside showers, slivers, and the top dish bein a little high fer me.... maybe there isn't a door???
From here there looks to be a slope on the floor.. What up??
Did he leave the spacers in? Is that cloudyness grout film? Are those circles on the tile or on the lense of the camera... Help us out here a little.. I'm dyin...
mm (aka "Paco")
Unread 01-24-2008, 02:50 PM   #5
jd77
jd77's Avatar
Sorry guys - got sidetracked. Be back shortly with more pictures and an explaination.
JD
Unread 01-24-2008, 02:55 PM   #6
jd77
jd77's Avatar
You can't see in the pictures but the edges of the tile were chipped. The contractor installed the tile straight joint but the client wanted it running bond. He chipped the tiles getting them out and re installed them that way. Whe she asked about the chips he wanted to paint them.
Other than that it looked like an average job from the outside. Given some of the stories she told me about the tile guys - I recommended a complete redo.
When I started the demo here are a few things I found......
JD
Unread 01-24-2008, 03:05 PM   #7
jd77
jd77's Avatar
Lots of Hardibacker with metal corners everywhere
drywall screws used
No liner on the seat
Hundreds of nails through the liner that was down
No blocking at the door
missing insulation
missing vapor barier
electric wiring in direct contact with copper pipes in the shower
electric heat mat installed with duct tape at the perimeter
rotten subfloor left intact
wood strips left in shower bed
no prefloat
thin set used for shower floor base
JD
Unread 01-24-2008, 03:33 PM   #8
Saldibs
Tile Contractor -- Boston North Shore
Saldibs's Avatar
Send a message via ICQ to Saldibs
You can do it - We can help, or Why do it once when you can do it twice.
Sal
http://www.youtube.com/saldibs
There is a right way and a wrong way, take your pick!!
You can only choose one!
elitetileco.com
Saldibs is offline   Reply With Quote
Unread 01-24-2008, 03:36 PM   #9
Art in Stone
Flooring Contractor -- Las Vegas
Es Muy Bueno!!!
Ramon
"If you don't have the time to do something right, where are you going to find the time to fix it?
Stephen King
Art in Stone is offline   Reply With Quote
Unread 01-24-2008, 05:05 PM   #10
tiledood
Pronounced Leh'-Nerd Skin'-Nerd
Send a message via Yahoo to tiledood
Wow! Thanks for sharing.
(edit)- What am I seeing in the third from last photo? It looks like a wood frame caulked to the top of a liner but the frame has a liner on top of it? Do I have it right?
Bob
tiledood is offline   Reply With Quote
Unread 01-24-2008, 05:32 PM   #11
K_Tile
Member of Million SF Club!!
You are her savor!
Unread 01-24-2008, 06:04 PM   #12
I think I seen some of that stuff he did in the books they sell at the big Stores.....
at least the rip out was easy !
Unread 01-24-2008, 06:26 PM   #13
madronatile
Nails through panliner? No problem. This guy decided his curb needed to be higher after he wrapped it in panliner. Don't know when he was planning to tile the wall!
Matt
www.madronatile.com
Unread 01-24-2008, 06:49 PM   #14
jd77
jd77's Avatar
That's what it looks like Bob but that is just an imprint on the thin set that they poured in the pan. They left the wood float strips in the floor and used a trim nailer to put hundreds of finish nails into the strips to nail them to the floor (through the liner!)
But hey - at least they caulked the wood strips down to the pan with White Lightening
Here's a closeup.............
JD
Unread 01-24-2008, 07:19 PM   #15
Splinter
Splinter's Avatar
Ho- Leeeeeee Crap!
Here's a snapshot of lovely mastic on backerboard drywall screwed through liner on curb.... I pulled out the cracked grout in the corners of this shower too and could see wood studs, plain as day.
Alex
