Unread 11-22-2014, 11:05 PM   #19966
Kilauea
LT
Kilauea's Avatar
Rich,Ive done a shower with a similar listello.Must be an Intceramic series.
*L.T.*
tandctile-dot-net
2nd generation tile installer
Kilauea is offline   Reply With Quote
Unread 11-23-2014, 10:48 AM   #19967
Arizona Floors
ReTile
Arizona Floors's Avatar
Rich the work looks good.
But, your not worried about waterproofing the screws or taping the joints prior to waterproofing? (It appears the back corners didn't even get waterproofing)
Arizona Floors is offline   Reply With Quote
Unread 11-23-2014, 01:10 PM   #19968
Autoplay
Tile Setter
I addressed what you stated to this contractor several years back....and his reply was it's denshield etc,and doesn't need waterproofing etc. I did waterproof the Very Rough/hacked exposed edges of the denshield,and where sheetrock hackers did a patch in the denshield.
The pans aren't even waterproofed again,stated to contractor in past what happens etc with depressed slabs/pans with no pre-slope or waterproofing....mold/mildew pockets etc and again he states not needed for "florida" code. He and plumber more worried about 2" drop of drain to finish,elevation. Go figure. This is also 1st floor/slab elevations. 2nd story or higher,in FL,code was passed about ten years ago regarding preslope under liner/waterproofing etc.
Sadly,with most here,it's a losing battle,discussing proper procedures etc....as most will look for the person/company to do it their way.
LT...I didn't purchase/order materials,GC did. I only gave GC footages required.
Here's what I have visually of product...
Rich
Autoplay is offline   Reply With Quote
Unread 11-23-2014, 01:15 PM   #19969
jondon
jondon's Avatar
Started a floor Wed. in Morgantown PA. Started the tile on Friday,
Crossville 18" Alamo Ecocycle Americana. Customer had a second floor leak on a valve while they were away so it went down and destroyed their kitchen. All the cabs out. Pulled out the linoleum and luan put down ditra. Only one spot in the subfloor had water damage so we pieced in new plywood. And of course with the cold weather we are set up inside
Jon Donmoyer
JD Tile
CTEF Certified Installer #825
Unread 11-25-2014, 03:13 PM   #19970
Autoplay
Tile Setter
Progressing along
Rich
Unread 11-26-2014, 03:14 PM   #19971
Autoplay
Tile Setter
Level screeds for glass doors
Rich
Unread 11-26-2014, 08:33 PM   #19972
studderin
thanks for the info on that mosics rich. I never liked that sheet layout with the sqare and smaller standing up rec. look inlines. But cut down for some reason dost look annoying like it dose full sheet. Anyone else or just me?hahaha
John
studderin is offline   Reply With Quote
Unread 11-27-2014, 09:52 PM   #19973
Autoplay
Tile Setter
Connecting the screeds,flashing.
Fair warning LT....I'm not the cleanest utensil,in the dishwasher!
Rich
Unread 11-29-2014, 08:32 AM   #19974
K_Tile
Member of Million SF Club!!
Uh-oh! Is that thinset being used as screed material Just kidding! Looks nice.
K_Tile is offline   Reply With Quote
Unread 11-30-2014, 03:51 PM   #19975
Autoplay
Tile Setter
Shaving shelves installed,per customer/homeowners request.
Rich
Unread 11-30-2014, 09:09 PM   #19976
Kilauea
LT
Kilauea's Avatar
1st pic-Doing take-offs and plans arent to scale (bang head)
My new apprentice wanted to learn how to mud walls.This hispanic kid has alot of drive.I walked him thru the Big limestone shower,and in the one pic where he is pointing at the wall,I let him do that on his own.
*L.T.*
tandctile-dot-net
Unread 12-01-2014, 02:22 PM   #19977
Floorit
Tile, Stone and Hardwood
Floorit's Avatar
Porcelain tile plank job with a little different plank style in Collierville, TN.
Tile is Emser Tile Modena Elm, 6x36, grouted with TEC Warm Taupe over Ditra XL with a little help from MLT.
Ray
Germantown Tennessee Tile Stone Hardwood Installation
NWFA Member
CTEF Certified Tile Installer
Tennessee Installer of Schluter Kerdi Waterproof Showers
Tennessee Installer of Laticrete Hydroban Waterproof Showers
"Life is pretty simple:you do some stuff. Most fails. Some works. You do more of what works. If it works big, others quickly copy it. Then you do something else. The trick is the doing something else." Leonardo Da Vinci
Floorit is offline   Reply With Quote
Unread 12-01-2014, 03:23 PM   #19978
Nice looking Ray. That looks like the Cerdomus "Over" series I just did.
Unread 12-02-2014, 09:14 PM   #19979
Brad Denny
Tile Contractor Nashville, TN
Brad Denny's Avatar
Anyone else deciding to work outside? Finally getting back to this pool project.
Brad
Brad Denny is offline   Reply With Quote
Unread 12-03-2014, 07:58 PM   #19980
jd77
Tile and Stone Setter
jd77's Avatar
still outside!!
That looks familiar Brad
Just took the tents down on this one Saturday and moved them to another job.
Your tenting looks great. How do you do yours?
JD
"Consider any individual at any period of his life, and you will
always find him preoccupied with fresh plans to increase his comfort."
Alexis de Tocqueville
jd77 is offline   Reply With Quote
Noob - questions and (eventually) progress pics hamfist Tile Forum/Advice Board 1 01-29-2011 09:19 AM
Kerdi shower in progress -- 5 pics 4 questions ritch Tile Forum/Advice Board 4 04-20-2009 11:32 PM
Another job finished up (pics) Chris H Tile Forum/Advice Board 10 04-01-2008 06:21 AM
