Unread 05-31-2006, 01:42 PM   #1
RachelandJon
Unhappy Porcelain Tile
We are attempting to install Porcelian Tile on our backsplash in kitchen. However we are using 17" *17" Floor tile. We are having some difficulty being able to cut out squares in the center of the tile for our outlets and light switchs. We have tried the Roto Zip bits for tile and a handheld tile saw, and nothing will cut through, it just burns out the bit. Do you have any suggestions??
Thanks much
RachelandJon is offline   Reply With Quote
Unread 05-31-2006, 01:55 PM   #2
oogabooga
An angle grinder with a diamond blade will do the trick, but you may first want to try getting hold of a diamond cutting disc for your rotozip.
Rob.
oogabooga is offline   Reply With Quote
Unread 05-31-2006, 02:12 PM   #3
austinpower
www.CoolAustinPads.com
Angle grinder at Harbor Freight Tools: 12 bucks.
4" diamond blade at Harbor Frieght Tools: 15 bucks.
Being able to cut squares in porcelain tile: priceless.
-Efren
"Your quote here."
austinpower is offline   Reply With Quote
Unread 05-31-2006, 02:36 PM   #4
Mike2
Rachel, there is a thread in the Liberry on cutting holes through porcelain that might give you some ideas.
Glad you joined us by the way.
Unread 05-31-2006, 03:10 PM   #5
RachelandJon
Red face Porcelian Tile
Thank you guys, I hope this works. We are having a big party next weekend and need it done by then!?!?!
I appreciate your advice.
Rachel
