Unread 09-04-2016, 10:03 PM   #1
armina
Darkening Marble Tile or Marble Tile Removal
Our tile guy installed our 8x16 polished white marble carrera in our master shower without doing a dry run. Now, we have a few tiles that are clearly whiter than the majority of the other tiles. Is there an enhancer you would recommend to darken these up so that they are a less noticeable whiter color? We tried a Custom aquamix enhancer and another enhancer that had the "ice" in the name. Nothing seems to work as the tile looks exactly the same when we apply the enhancer? Any recommendation? Could the fact that it be polished be preventing the enhancer from working?
If this doesn't work, we would need to remove the tile but really worried that this is going to damage the other tiles and more importantly, the dense glass behind it causing a water leak in the future. We would really appreciate any techniques to help us safely remove the tiles.
Super disappointed but hoping this group can help us fix this mess. Please help!
Armina
armina is offline   Reply With Quote
Unread 09-04-2016, 10:49 PM   #2
Welcome to the forum, Armina.
Sorry to hear of your troubles.
1) Were all the tiles set at the same time, or is there any chance that the lighter tiles were the very last tiles to be installed?
2) Is there any chance that the lighter tiles were set with a different setting material than the darker tiles?
3) What does your installer say about the lighter tiles and do they have any proposal to remedy?
Unread 09-04-2016, 10:56 PM   #3
I have the same questions. Usually when we see that, those tiles were lighter before they were ever installed.
Unread 09-05-2016, 07:21 AM   #4
evan1968
Not So Senior Contributor
evan1968's Avatar
Gotta shuffle those boxes, especially marble. Those lighter tiles should have stood out to him.
Craig
Commercial Tile Installations
KEEP CALM and TILE ON
Unread 09-05-2016, 07:25 AM   #5
Dave Gobis
da Man!
Dave Gobis's Avatar
From what you told me before, I still think it may dry out. You said they were getting lighter as they set longer. Putting marble over an impervious surface gives the moisture only one way to go, out the front. As I mentioned, this is not a new problem.
Unread 09-05-2016, 09:26 AM   #6
Cain
Cain
I can never figure out how God can make the same rocks different colors.
Doesn't he know clients want them all the same
Cain Curtis
A Tile Experience
Certified Tile Installer #362
Cain is online now   Reply With Quote
Unread 09-05-2016, 01:40 PM   #7
eurob
Not...Sure
It is called packaging . Ask how the clients feel when asked to purchase 20 or 30% more of the finishing material in question -- marble -- to just be able to blend them in a balanced shading ?
From the photo , doesn't matter where you insert the white ones , they will always be different than the others.
Roberto
Unread 09-05-2016, 04:18 PM   #8
armina
Removing marble
The installer incorrectly installed these. They were all installed at around the same time, more than 3 weeks ago. They should have been removed but weren't. They are all dried and were just a different color. Any suggestions on how to 1) darken the tile?
Otherwise, some advice on how to remove would be greatly appreciated. Any special tools that can help?
Installer doesn't have a recommendation so I am reaching out to this group of experts for suggestions.
Armina
Unread 09-05-2016, 04:26 PM   #9
What's behind the tile? CBU, a membrane, deckmud, other? Normally, to remove a tile, you remove the grout around it, then smash it in the middle and try to get pieces out. If you don't remove the grout first, you'll crack adjacent tiles, but if it's on a waterproof membrane, it becomes a bigger problem trying to make a viable seam once the old tile is out.
Unread 09-05-2016, 04:46 PM   #10
ded dux
ded dux's Avatar
They probably all looked that white before install, the others have changed due to moisture but those may have had something on them to prevent or retard the moisture from getting into the stone?
Don
ded dux is offline   Reply With Quote
Unread 09-05-2016, 06:49 PM   #11
In my opinion, if the installer made the mistake of installing them, then he should replace them. I wouldn't wait for a recommendation from him but rather recommend to him that he made the mistake and should replace them himself.
Unread 09-05-2016, 09:36 PM   #12
What Davy said. Hopefully, you haven't paid the entire bill as of yet?
And if there's anything else you'd like to add out here in public to shed light on anything, feel free. It sounds like you've contacted at least one member here privately and shared something we haven't been made aware of. My main concern is that we may be giving you bad advice based on only half the facts.
Unread 09-08-2016, 11:07 PM   #13
Are you still there, Armina? Any change in appearance?
Unread 09-09-2016, 07:38 AM   #14
MAPEI - Technical Service
Company Representative
Unfortunately any enhancing sealer you put on the stone now won't do much, you've already sealed all of the pores with the other products you've tried. You could try this product and then this product which may darken the tiles a couple of shades. The other solution, unfortunately, is a tear-out and re-install because it would be very difficult to remove the tiles without impacting the waterproofing.
Holden
http://www.mapei.com/US-EN/
Unread 09-09-2016, 01:55 PM   #15
We are all probably guilty of doing this at least once. I was installing a marble floor a while back, 1 inch hex and all the sheets were matching pretty well. I installed about half of it and then I saw it, 1 12x12 sheet that was lighter than the rest. The thing is, it was out in the middle of the floor but I did manage to reach it. It stood out like a sore thumb. I knew it wouldn't fly so I went ahead and removed it. The sheet was wasted but everyone was happy in the end.
This kind of thing usually happens to me when the customer picked up the tiles from a big box store.
Carrara Marble Shower Floor Darkening OzCanuck Tile Forum/Advice Board 24 08-07-2016 03:27 PM
Marble tile darkening stidesforty Tile Forum/Advice Board 6 12-12-2015 05:40 PM
Darkening grout/tile on tumbled marble backsplash (pre-grout sealant used) NovicesRus Cleaning, Restoration and Sealing 1 03-13-2008 09:24 AM
Darkening grout/tile on tumbled marble backsplash (pre-grout sealant used) NovicesRus Tile Forum/Advice Board 2 03-12-2008 08:57 PM
Need help in removal of marble tile on wall Harleyguy Tile Forum/Advice Board 2 08-05-2006 07:29 PM
