Closed Thread
Unread 05-30-2005, 08:06 PM   #1
wwilson1
wwilson1's Avatar
Drill for mixing thinset?
I bought a spiral mixer from Lowes the other day and come to find out I'll need a 1/2" drill to operate it.
I would like a recommendation for a corded drill that will work for about 1/2 bag (25lbs) batches. It looks like there are two versions of lower end drills out there.
1. 0-700 rpm with 2 or 3 stage gear reduction.
B and D $49.00 at lowes
Craftsman
2. 0-2700 rpm.
Champion. I'm a little worried about the higher rpm's, which may translate to poor torque at lower (mixing speed?)
The drill will be used for doing a couple small bathrooms, and then I figure it will end up used about as much as my current 3/8 corded drill (rarely.)
What kind of RPM range should I be mixing at?
Thanks, Wayne
wwilson1 is offline
Unread 05-30-2005, 08:13 PM   #2
doitright
doitright's Avatar
Hi Wayne
The lower the rpm's the better. Usually around 350 won't allow too much air entrapment.
John Koessler
doitright is offline
Unread 05-30-2005, 08:21 PM   #3
jay f
Illinois Flooring Man
Send a message via Yahoo to jay f
Generally, you never want to mix faster than 450 rpm. Mixing drill that we pros use generally will cost from $200 to $450 . I have heard from a few part time tile setters that have had very good luck with the Dewaldt 1/2" heavy duty, about $160 . I would never dream of trying to use a 3/8" drill, it will probably get burnt by the third bucket of thinset.
Jay
give me thin set or give me death!!!
jay f is offline
Unread 05-30-2005, 08:37 PM   #4
JR
Lowe's has a very powerful 1/2" Hitachi drill that I bought in an emergency to mix mortar. It costs about $90.00 and will last a long time. I don't use it as my main mixing drill, but it still gets plenty of use. It is going on a year now and works just fine.
JR is offline
Unread 06-02-2005, 09:23 PM   #5
Mike_balt
no 0-2700rpm drills
FYI _ When my last 1/2 drill died, I bought a high torue dewalt drill that advertiesed 0-2500 rpm. I figured it had enough amps and was variable speed, so it should work. NOOOOOO
the drill would not spin thinset at low speed. In fact, it would just sit there humming until I gave it more juice at which point it would break free and spin at something like 1000 RPM thereby throwing mortar all over the place. When I'd modulate the trigger, it would just alternate between no spin and full bore. So no more for me. I took my cheap, $99 craftsman cordless that has a switch for hi and lo torque and mixed what I needed for the day and threw the brand new Dewalt in the closet, likely to never be used again.
Mike_balt is offline
Unread 06-02-2005, 10:36 PM   #6
JTG
JTG's Avatar
Look at a pawn shop for a drill motor.
Jerry
Santa Seattle
Ballard
JTG is offline
Unread 06-03-2005, 06:12 AM   #7
Shaughnn
Trowel Monkey
Shaughnn's Avatar
I agree with Jerry about looking at pawn shops. When looking at used tools, I always check the condition of the power cords but also look inside the motor housing for excessive dirt and grime. Many sellers will clean up tools before selling them by using a solvent to wipe down all of the surfaces. Grime or rust inside the motor housing tells me that a tools wasn't well taken care of by the previous owner and that the tool may actually be a three-legged pig on it's way to the butcher. Check the condition of the chuck also as some people would rather use a wrench to tighen their chuck than a chuck key. A chuck that's really chewed up thell me that the previous owner might have had some trouble keeping the chuck tight.
Best of luck,
Shaughnn
Shaughnn is offline
Unread 06-03-2005, 07:17 AM   #8
wwilson1
wwilson1's Avatar
Okay, given my circumstances: I'm cheap, and only need something just better than doing the mixing by hand. I'm going to try this:
Harbor variable speed unit.
I accidentally bought a non-variable ($39 not $59) unit and have to take it back.
Non-variable
I'll give an update if I ever get around to actually laying tile in my bath remodel.
Wayne
wwilson1 is offline
Unread 06-03-2005, 11:25 AM   #9
Rd Tile
Tile Man
Rd Tile's Avatar
Love my Milwaulkee.
Rd Tile is offline
Unread 06-03-2005, 11:33 AM   #10
peterd
peterd's Avatar
Wilson,
The Harbor Freight variable speed will do ok for you. Thats the one I used and it's still going. The only problem is under heavy load the drill will not keep the speed slow but gets a mind of it's own. But then again, you get what you pay for.
-Peter D
peterd is offline
Unread 06-03-2005, 11:34 AM   #11
jdm
jdm's Avatar
I thought that was what plumbers use to increase the deflection of joists!
jeff
Go Rutgers!
jdm is offline
Unread 06-03-2005, 11:49 AM   #12
JohnB
Mixing by hand, anyone? How long, how hard? I dont really want to buy another drill right now. I have tow cordless drills, a small screwdrive type 7.4V and a craftsman 12V. I dont think either has the muscle.
JohnB is offline
Unread 06-03-2005, 11:53 AM   #13
jdm
jdm's Avatar
John --
For smaller jobs, hand mixing is a possibility. However, hand mixing will not achieve as smooth a result as power mixing, and us DIYs can use every advantage we can get.
jeff
Go Rutgers!
jdm is offline
Unread 06-03-2005, 12:24 PM   #14
Alia
"Mixing by hand, anyone? How long, how hard?"
I am doing a small bathroom project and have been mixing my thinset by hand - 3 gallon bucket and a wooden spoon. I have been getting nice results - and the added bonus of muscles...
Alia
Old age and treachery always overcomes youth and skill.
Alia is offline
Unread 06-03-2005, 12:37 PM   #15
Revstriker
Craftsman
2. 0-2700 rpm.
Thanks, Wayne
I purchased the B&D model you have here when my older drill finally quit. Although it's not one I would pick if you were doing this kind of work everyday, but for just a few small jobs, it should work fine. I've managed to tile a large kitchen, breakfast area, good size laundry room, 2 master bathrooms, and a regular bathroom, and my B&D is still working fine. One thing to note though: my thinset batches were normally about 16 lbs each (1/3 of a bag).
Revstriker is offline
Closed Thread
