Unread 07-11-2019, 07:40 PM   #31
HughM
Can I sandwich the mortar bed in Redguard?
Help! My contractor thinks we should install Redguard as a crack membrane on the old concrete slab before doing the sloped mortar bed. Then he said we could either top the mortar bed with more Redguard for waterproofing, set the pavers with thinset, and seal the grout. OR, we can skip the top Redguard layer and just use the sealant on the grout for waterproofing. Will either of these work? Is it a problem to sandwich the mortar bed with Redguard?
Hugh
HughM is offline   Reply With Quote
Unread 07-11-2019, 10:09 PM   #32
There is no advantage to applying the RedGard before installing the sloped mortar bed.
What is the plan for this mortar bed? Are you planning a bonded mortar bed or an un-bonded, reinforced mortar bed?
Using a sealant on the grout is not in any way a method of waterproofing. You want a direct bonded waterproofing membrane on top of your sloped mortar bed and I'd recommend a sheet-type membrane, but RedGard properly applied would work.
Unread 07-12-2019, 05:29 AM   #33
HughM
The mortar bed is bonded. His reason for the Redguard under the bonded mortar bed is to serve as a crack suppression membrane for the cracks in our old concrete base. I realize we should have started over with a new concrete base but we didn't and this is his idea to help with what we have. Will it create any additional problems to do it his way and apply both layers? He comes in an hour and I don't know what to do!
Hugh
Unread 07-12-2019, 07:55 AM   #34
Hugh, there are no crack "suppression" membranes in the ceramic tile industry. There are crack "isolation" membranes available that are designed to prevent horizontal movement cracks in the substrate from telegraphing through the tile surface, but they do not do anything to suppress any cracking in the substrate.
In your application, especially with the surface condition we see in your photos, crack isolation is not likely to be effective even if you tried to tile directly to the concrete and I doubt the manufacturer would pretend the RedGard or similar would give any protection at all with a bonded mud bed on that surface and tile above that. Indeed, the only thing the RedGard would do in that application is ensure that any moisture that gets down past your mud and tile installation would remain there permanently, or at least until your first good freeze.
I think you'd be far better off bonding your mud directly to your concrete with a slurry of thinset mortar (a cleavage membrane and reinforced mud bed would be better) and using a good crack isolation/waterproofing membrane on top of your mud bed, flashed appropriately to the wall of the building to prevent any water getting down into the substrate package.
Good flashing, good waterproofing, and good slope away from the building are your best hope for a lasting tile installation.
Unread 07-12-2019, 07:02 PM   #35
HughM
Thank you CX
Well always more to learn and thank you again for the valuable info! Here's another question- does anyone know of a good substitute for bond breaker tape? I want to bridge an expansion joint with Redguard and their data sheet says to cover the joint in the mortar bed with bond breaker tape, then top with Redguard. Also need to prevent 3 way adhesion at the bottom of a shallow expansion joint where backer rod won't fit. Our local stores have never heard of bond breaker tape and don't stock it.
Hugh
Unread 07-12-2019, 09:12 PM   #36
Hugh, if you Google bond breaker tape you'll find plenty of online sources.
Unread 07-13-2019, 01:55 PM   #37
HughM
Crazy idea?
Well true confessions here. The contractor went ahead and put Redguard on the part of the concrete slab that has cracks. I stopped him from putting it on the whole thing. SO, on Monday he returns to add the sloped mortar bed, which will then also be topped with Redguard. Trapping any moisture as you pointed out. Before he returns, I am considering this idea- drilling small holes in his Redguard on my level base. For drainage. While I have a last chance. Crazy?
And the bond breaker tape- the soonest online delivery won't be for 10 days, which won't work. I read someone elsewhere who said that electrical tape will work in a pinch. Or I have some Zip acrylic flashing tape...?
Hugh
Unread 03-30-2020, 04:12 PM   #38
HughM
Question on thinset for laying pavers on concrete sidewalk
Hi, getting ready to lay pavers now on an adjoining concrete sidewalk. These are full 2 1/8 thick brick pavers and we do live in an area subject to freeze and thaw. Our local stores carry Mapei products. Was looking at their large stone and tile product which is polymer modified. However it says not to use it in areas subject to severe freeze and thaw. Don't know if that applies in our location. (NE Oklahoma) Could you advise?
Thank you!
Hugh
Unread 03-31-2020, 07:44 AM   #39
HughM
Thinset Advice
Need to set 4x8 pavers on concrete sidewalk in NE Oklahoma (zone 6) area which does have freeze and thaw. Will be using thinset but want to buy the correct product. We have Home Depot and Lowes products in our area. Which of their products do you think would be best for this?
Hugh
Unread 03-31-2020, 08:29 AM   #40
Basically, any mortar that is rated for exterior use. You can find that information on the bag.
At HD, Versabond is a good product.
Any cracks or joints in the sidewalk?
Unread 03-31-2020, 09:52 AM   #41
HughM
Thanks Kevin. We have 2 isolation joints where the sidewalk butts up against the porch and then also the driveway. And we made 2 other control joints when we poured the sidewalk. Our plan with the pavers is to maintain those joints. No cracks though, its a new sidewalk (6mos new). We are thinking we should first spread a slurry bond coat then top with the thinset using a 1/2" trowel, laying pavers perpendicular and compressing. Sound about right? (never done this of course)
Hugh
Unread 03-31-2020, 10:17 AM   #42
Any pictures of the sidewalk?
Unread 03-31-2020, 11:23 AM   #43
HughM
Here's a pic of the sidewalk
Hugh
Unread 03-31-2020, 05:02 PM   #44
Hugh, I can't tell from your pic, was the concrete poured to the right height for a thinset application and still finish out flush with the patio and driveway?
Unread 03-31-2020, 07:07 PM   #45
HughM
Yes that was what we were trying to do. Allowed for the thinset at compressed thickness of a minimum of 1/4" then the paver height, should come to flush with the porch and the driveway. Here's a pic
Hugh
Jacuzzi to Shower Retro boulderz Tile Forum/Advice Board 6 01-09-2019 11:04 AM
Retro Half-Bath Redo lojoma Tile Forum/Advice Board 5 05-24-2017 05:49 PM
Shower stall tile leak -- retro questions stevebass Tile Forum/Advice Board 3 02-07-2014 11:29 AM
Kerdi retro drain figaro Tile Forum/Advice Board 16 01-10-2012 06:39 PM
Tiling a concrete porch with issues Retropia Tile Forum/Advice Board 22 05-29-2007 08:28 PM
