Old 07-13-2009, 09:55 PM   #1
KiKi Mann
need help on how to fill gap between marble shower wall and floor
First off -- this is one of the NICEST sites I have found yet! -- I appreciate the refined/constrained openness -- open, accessible, friendly -- but with some good boundaries in place! NICELY DONE!!!
OK -- 'some' time ago (a few years now ...) I had a problem with moldy caulk and decided to replace it. I scraped off ALL the caulk, cleaned the tiles (marble) and joints with bathroom cleaner, sprayed bleach and some other anti-mold stuff on the grout and into the cracks, and cleaned the tiles with alcohol to remove any residue of the soap that I used to clean the tiles. I then proceeded to re-caulk. First problem is the caulk didn't seem to bond very well. But the bigger problem is that on one edge where the floor meets the wall the grout has fallen out, and there is nothing behind the crack to hold new grout in. Shouldn't I re-grout before I try to caulk? The gap is way too large to just caulk (I think). Somebody at work suggested injecting expanding foam to create a backing and then grouting against that, but I'm not sure that would be a very sturdy solution. But that may just be as good as it gets though. The shower is currently holding several boxes of misc. junk, but I would really like to be able to use it again ... please let me know what might work.
Kiki
Kiki
KiKi Mann is offline   Reply With Quote
Old 07-13-2009, 10:07 PM   #2
Welcome, KiKi. Glad you like it around here.
Can you show us a picture? Or can you tell us how large the grout piece that's missing is?
For the caulk you've purchased. Is it 100% silicone, acrylic, or.....?
Old 07-14-2009, 09:08 PM   #3
KiKi Mann
Thanks Tool Guy - kg -- will do --
... but it may be a day or two before I can send them -- I have to excavate all the boxes storage out of the shower before I can get a picture -- I'll send one as soon as I get it -- thanks for your patience ...
til then ...
Kiki
Shower floor/wall gap caulking (is this not enough?) MikeKarina Tile Forum/Advice Board 10 06-30-2012 05:36 AM
shower floor gap to wall tile goof up help JamesL Tile Forum/Advice Board 3 07-20-2008 07:58 PM
Shower Tiling - corner gap fill issue kkees Tile Forum/Advice Board 19 05-31-2007 07:25 AM
How to fill gap between Tub and wall John from Philly Tile Forum/Advice Board 22 11-13-2004 04:46 PM
tile up to replaced wall, How to fill gap timtest Tile Forum/Advice Board 2 02-21-2004 07:11 PM
