Unread 01-02-2011, 12:57 PM   #1
REXAMUS
Water heater / Water pressure
Does the water travel from the water heater to the water pressure tank and then distributed throughout the house? Also, I was looking at my pressure tank and the gauge says it's at 40psi. There is a knob on some piping that leads out of it and goes to the water heater. It's turned all the way to one side like it's either all the way on or all the way off. I didn't even pay attention to which way it was turned though. Would this be the knob that controls the pressure? I can take a picture if necessary.
Trey
REXAMUS is offline   Reply With Quote
Unread 01-02-2011, 01:16 PM   #2
Yeah, pictures would tell a lot. Try to get some that show as much of the system as you can.
Unread 01-02-2011, 01:29 PM   #3
Davestone
Florida Tile & Stone Man
I've been on pumps most of my life.
A handle type valve will be closed if it is sticking out at an L from the pipe(usually)
The air bladder will go almost anywhere in the line,it only keeps constant pressure so the pump doesn't cycle off and on.The air tank has it's own pressure when there is no water pressure,usually less than half the line pressure.
A pressure gauge on top of the pump will give you the pressure fror kick on and off.Usually20/ 40 p.s.i.
http://Davestonestile.com
Water heater forum chubyball Tile Forum/Advice Board 3 05-31-2009 04:34 PM
Tile saw water heater AZ10sBum Tile Forum/Advice Board 2 04-12-2009 08:53 PM
Gas Water Heater ddmoit The Mud Box 29 01-15-2008 04:18 PM
bucket water heater? Jon1029 Tile Forum/Advice Board 5 01-10-2005 06:03 PM
Water pressure John Bridge Professionals' Hangout 38 10-02-2002 06:38 AM
